Stumped
  • rond7485
  • rond7485's Avatar Topic Author
5 years 10 months ago #45303 by rond7485
Stumped was created by rond7485
I have a 2002 ford f150 4.6L the codes say I'm to lean on both banks. My s.t.f.t. is at -9.7% on both and my l.t.f t. Is at 29% on both banks. The truck is barley running. What could cause this. I can't find a vacuum leak anywhere, the maf sensor seems to be working fine I cleaned the injectors. Changed the plugs, checked the fuel pressure which was good. I just can't figure it out.
5 years 10 months ago #45307 by Hardtopdr2
Replied by Hardtopdr2 on topic Stumped
smoke test intake and check egr tube going from egr to intake they tend to leak where the 2 bolts mount it to the intake "there should be a calibrated gasket there". also another issue is the imrc controller valves in intake tend to get gummed up and stick shut or stuck open. you will have to peak behind intake and look down at the two rods going to the imrc butterfly valve rod and see if they are sitting loose "not connected to anything on one end".
5 years 10 months ago #45313 by willco
Replied by willco on topic Stumped
Can you give us maf and fuel trim data@ idle and 2500?. You have a vacuum leak but just have not found it yet it seems like
