'03 Corolla P0171 Issue
- 69Camaro
- Thank you received: 2
Questions: Using scan data (vs back probing) what can I do to test the O2 sensors? Any other tests to recommend finding the issue causing the code?
Thanks for posting your fuel trim number, great to see.
Do you have access to the freeze frame data? That'd be the perfect place to start, as it'd point directly to the conditions during which the code set. If you can post the freeze frame, we can help point you in the right direction.
As far as your O2 sensors, if you saw them switching at idle and off idle, then I'd say they're OK for now. That doesn't mean you can't have an upstream sensor failing intermittently, we just don't have any evidence of that at this point.
- cj1
- Thank you received: 12
If so may be leaking cold start up
Freeze frame should tell
- matt.white
- Thank you received: 29
- Doc n2mx
- Thank you received: 10
I don’t know if you have found the problem or not, but here are a few things I would test
The most common issue that I have found was the MAS
I would test the Mas and if it was replaced make sure its an OEM replacement I have found that some after market sensors don’t work.
If you have freeze frame data look to see what the engine temp was. This will let you know if it needs to be cool or hot to find the leak.
Make sure that you are looking when at the same conditions.
Some guy (Paul Danner ) uses a water bottle to find the leaks check out his video, He does it so well.
Next thing are the plugs pull them and look at tem and read what they tell you, you can learn a lot for what you see,,, or don’t see!
Also don’t for get to check out the PCV system…..
Good Luck!
- 69Camaro
- 69Camaro
69Camaro wrote: Great suggestion on the Fuel Injectors, what is the best way to test the injectors themselves to verify or locate the one that may be bad (in the case it is only one bad vs all 4)? I'll do the WOT test and see what I get.
The classic way to test for flow issues is an injector balance test. This video is right up your alley, same engine and everything!
Let us know what you find with the WOT test and freeze frame.
- 69Camaro
