2006 jeep grand cherokee
- Chevyman
5 years 9 months ago #46318
by Chevyman
2006 jeep grand cherokee was created by Chevyman
My son bought a 2006 jeep grand cherokee. A few times I've had a intermittent problem, the dash goes out, radio stops working, blower fan stops and head lights go out . Engine stays running and fog lights stay on. They after a few seconds everything returns to normal. Does the instrument cluster have a module on the can bus. Anyone have a schematic of the instrument panel. I know this being intermittent problem may be hard to find.
- Cheryl
- Thank you received: 215
5 years 9 months ago #46325
by Cheryl
Replied by Cheryl on topic 2006 jeep grand cherokee
Sounds like a ground problem. I’d check at the blower motor since it’s the easiest of the loads.
- Chevyman
5 years 9 months ago #46326
by Chevyman
Replied by Chevyman on topic 2006 jeep grand cherokee
Thanks would that effect the head lights and radio also
- Chevyman
5 years 9 months ago #46327
by Chevyman
Also trying to find a wiring schematic
- Chevyman
5 years 9 months ago #46347
by Chevyman
It's odd when problem occurs you shut jeep on restart and everything goes back to normal.
- Hardtopdr2
- Thank you received: 150
5 years 9 months ago #46352
by Hardtopdr2
Replied by Hardtopdr2 on topic 2006 jeep grand cherokee
This could be an ignition switch issue. Since its a Chrysler see wiring diagrams to see if they all share the same key on function from switch then use a 4 amp bulb to test the key on feed from switch if it goes dim or out completely that would be the issue.
- Chevyman
5 years 9 months ago #46355
by Chevyman
Where can I find a wiring schematic on line
- Hardtopdr2
5 years 9 months ago #46357
by Hardtopdr2
