2007 tahoe air ride issues
  • cheryl hartkorn
  • cheryl hartkorn's Avatar Topic Author
9 years 8 months ago #6109 by cheryl hartkorn
2007 tahoe air ride issues was created by cheryl hartkorn
codes c0712-06 c0696 c0660.
a friend bought it at an auction said service air ride in cluster, found the fuse 62 missing under the hood. I thought wow that was easy compressor came on and it kept running and running until the rear end was at max height and kept running. went to relay and the module is continuously grounding it. unhooked relay and module checked for a short to ground found none. checked ride height sensors and the voltages are way off. I found the module above the spare tire like the fuel pump control modules are that fail left and right. the module was corroded and everything. could shake it and hear things moving around in there. have you guys run into this??
9 years 8 months ago #6115 by Tyler
Replied by Tyler on topic 2007 tahoe air ride issues
New one to me! Though, it sounds like no one learned from Ford's FPDM problems. :lol: Is your friend buying another module?
The most fun I've ever had with GM air suspension are the rear shocks that set C-codes. Boooo-ring.
  • cheryl hartkorn
9 years 8 months ago #6117 by cheryl hartkorn
Replied by cheryl hartkorn on topic 2007 tahoe air ride issues
yep he's buying a new module we will get it Thursday and program it. I might do a bit of dissecting when were done
