2008 dodge nitro 3.7L misfiring
- Mike T
- Thank you received: 2
5 years 8 months ago #47139
by Mike T
2008 dodge nitro 3.7L misfiring was created by Mike T
Okay im having all kinds of fun with this one lol. Let me tell you the hole story. the fan got busted some how and busted up the radiator. thats suppose to be the only thing wrong with it. lol, Well the injectors on #1 and #3 are not firing. the plugs looked rough so i changed them. The coils are firing good. injectors fire fine When I first fire it up then the computer shuts them down. if i unplug the number #2 coil wires and the injectors will stay firing on 1 and 2.lol any ideas??
- Cheryl
- Thank you received: 215
5 years 8 months ago #47142
by Cheryl
Replied by Cheryl on topic 2008 dodge nitro 3.7L misfiring
If ya don’t have a scope you could swap coils plugs injectors to other cylinders. See if the intentional shut down follows.
- Cheryl
5 years 8 months ago #47143
by Cheryl
Need to current ramp the injectors and coils
- Mike T
5 years 8 months ago #47155
by Mike T
Replied by Mike T on topic 2008 dodge nitro 3.7L misfiring
I do have a scope and everything seems to be fine when it first fires up
- Mike T
5 years 8 months ago #47156
by Mike T
The only thing that showed anything was when I was checking the amps on the main fuse to the injectors and one injector spike was missing#4 . I thought I had found it. Then hooked up the scope to the injector the coil and the low amp probe and it was all working properly. I still haven’t found out what could be the problem. I still don’t have the radiator and fan here yet but it’s ordered. So I can’t just run the the vehicle and keep looking. So it’s kinda a mess I should just wait until I can get that stuff in. But I’m not good at waiting lol
- Mike T
5 years 8 months ago #47185
by Mike T
Just wanted to give a update. I got to looking closer on the spark lines and the 2 cylinders that are misfiring the spark line seemed shorter. So I checked compression turns out my first thought is right them 2 cylinders are a little week and I’m betting the head gaskets the problem. So this one is going to need more then expected.
- Mike T
5 years 8 months ago #47186
by Mike T
But I sure had fun playing with the scope on that one!
