Electronic stop sig module to electronic stability controller.
So ive been chasing this stop lamp issue on a 2014 Hyundai Santa fe. Pretty sure i have narrowed it down. At the esc module plugged in, 12v. Unplugged, 12v. At the stop sig module, 12v volts. Unplug stop sig module, 0v. Stop sig module has input circuit going to ESC. Stop sig module also controls external lights which all work still. Did i make the correct call and saying the stop sig module was faulty? Yes i did power and ground checks at the esc. Its a funky set up for sure. Everything else works.
Theres 8 wires going from the ESC module to the Stop Sig module. 2 of those wires are going directly to the esc. The other 6 tested out as far as the brake switch function is concerned. Cant remember wire colors at the moment. But on the HAC/DBC wire was where i was reading 10 volts plugged in at the esc and 10 volts unplugged as well. Measuring the same HAC/DBC wire at the stop sig module, 10 volts plugged in. Unplugged, voltage goes away.
Last edit: 5 years 7 months ago by thomas.cochran.
