96 Jeep stall out problems
- Biily
5 years 7 months ago #47969
by Biily
96 Jeep stall out problems was created by Biily
Hi I have a question I have a 96 Jeep Grand Cherokee Laredo 4.0 straight 6 cylinder engine automatic 4 wheel drive Jeep..no skimer. No security system. The ECU went bad. .I went to junk yard bought 2 ecu's off of two 1996 Cherokee laradoes no skimer no security. Why would they have to be programed to run the engine in my Jeep .to my serial number what in God's name would be in the Jeep that has stored Vin numbers in it to cause a mis match and how can I jump all this if so.? There's all kinds of misleading info on the internet . My Jeep cranks and stalls I have 5 v and CPS / crk ps singals injector power 5 v but I get a code 12 that's the only code I have not pushed the reset switch on the dash.need help the Jeep I thought woul run if I jump the shut down relay it's only four pins .can I send a 5 v signal to a pin on the ECU and get it to run ?
- Cheryl
- Thank you received: 215
5 years 7 months ago #47990
by Cheryl
Replied by Cheryl on topic 96 Jeep stall out problems
So it’s a start stall issue? Maybe try sending your old pcm to be rebuilt if you don’t have programming abilities where you are.
- Biily
5 years 7 months ago #48007
by Biily
Replied by Biily on topic 96 Jeep stall out problems
We don't have any place around here to reright a Vin in an ECU and online people I'm sceptic of . Do you know of someone trust worthy?
- Cheryl
5 years 7 months ago #48008
by Cheryl
An autel or launch scanner would. Or a drew tech j2534 toolbox. Snap on won’t
- Cheryl
5 years 7 months ago #48009
by Cheryl
You could contact Spartan auto works they have a YouTube channel. He specializes in bench programming
