Odd cylinders no secondary waveform
- maldud
5 years 6 months ago #48084
by maldud
Odd cylinders no secondary waveform was created by maldud
98 Buick Regal 3.9 6 cylinder no turbo. Checking secondary waveform and have no waveforms on the odd cylinders. The even cylinders have a normal secondary waveform. The engine runs ok with no codes. After driving around 5 to 10 miles when I stop. The car has no acceleration. When I shut the engine off and re start it, the car runs normal. I am using a Hantek 8000c.
- Cheryl
- Thank you received: 215
5 years 6 months ago #48085
by Cheryl
Replied by Cheryl on topic Odd cylinders no secondary waveform
Is it running lean with the no acceleration problem? Look at o2 sensors see if they go rich or lean under load.
5 years 6 months ago - 5 years 6 months ago #48088
Replied by Chad on topic Odd cylinders no secondary waveform
I'm sure you meant 3.8L. This is a waste spark system. With companion cylinders/coil, one cylinder will fire positively, and the other will fire negatively. You will have to use the "invert" function, lower your "trigger" to below zero, or turn the "trigger" off to see the the companion ignition event.
Last edit: 5 years 6 months ago by Chad.
- maldud
5 years 6 months ago #48104
by maldud
Replied by maldud on topic Odd cylinders no secondary waveform
Thank you very much that sure makes sense to me now!
