2002 xtrail no ignition coil control
  • Truesoldier
  • Truesoldier's Avatar Topic Author
5 years 6 months ago #48293 by Truesoldier
2002 xtrail no ignition coil control was created by Truesoldier
I have good cam and crank signals but I don't have any control for the ignition coils. If I disconnect the cam sensor sometimes it starts up after a few cycles. I was taught that the cam is responsible for ignition coil control. Also if I disconnect the cam sensor I get a cam code so I think the computer is satisfied that the signal wire is received. I had a replacement computer do the same thing.
5 years 6 months ago #48324 by John Curtis
Replied by John Curtis on topic 2002 xtrail no ignition coil control
Truesoldier wrote: I have good cam and crank signals but I don't have any control for the ignition coils. If I disconnect the cam sensor sometimes it starts up after a few cycles. I was taught that the cam is responsible for ignition coil control. Also if I disconnect the cam sensor I get a cam code so I think the computer is satisfied that the signal wire is received. I had a replacement computer do the same thing.
How and where did you test for control to the ignition coils?
