2016 Sonata P0172
- Jalvrzjn
- Thank you received: 2
5 years 6 months ago #48341
by Jalvrzjn
2016 Sonata P0172 was created by Jalvrzjn
16 sonata has a p0172. Definitely running rich. Stft and ltft are negative at idle. When driving they start to go positive and even out. Then go negative at idle. A/F sensor changes with simulated lean condition(pulling vacuum hose) and so does o2 sensor. No sensor is stuck. Does not have a maf. Map reading is ok. About 1.2V at idle. Did find clogged air filter but no change after replacement. Check for clogged cat. Checked ok. Leaning towards leaking injectors. Has anyone experienced this on a GDI system? Can i test the injectors using a fuel pressure gauge and pulsing the injectors with an injector tester? Not sure if that works on a GDI. Any input is appreciated. Thanks in advance.
- John Curtis
- Thank you received: 111
5 years 6 months ago #48342
by John Curtis
Replied by John Curtis on topic 2016 Sonata P0172
I don’t recommend using anything other than a scan tool to do an injector drop test. GDI injectors might risk getting cooked any other way.
- Jalvrzjn
5 years 6 months ago #48343
by Jalvrzjn
Replied by Jalvrzjn on topic 2016 Sonata P0172
Ok. What am I looking for when doing an injector drop test with my scantool?
- John Curtis
5 years 6 months ago - 5 years 6 months ago #48345
by John Curtis
It works the same as the test you were mentioning except you are using the scan tool to bidirectionally do the test. GDI injectors are low resistance so using a tool to pulse them may not be a good idea. In this case it’s likely not even necessary.
Do you have proper fuel pressure? Monitor fuel pressure for 5 minutes after vehicle is off to see if you have injector leakage. Also be weary of temperature sensors causing an over fuel lung issue.
Last edit: 5 years 6 months ago by John Curtis.
- Jalvrzjn
5 years 6 months ago #48348
by Jalvrzjn
Thanks for your reply. Ill have to check pressure again. The pressure specs and how the scan tool measures pressure were different if i remember right. I did the best I could using voltage from the fuel rail pressure sensor and the spec sheet. Looked to be ok. I can only disable injectors with the vehicle running. I did notice that cyl 234 did not have significant drops in rpm when disabled. And cyl 1 had a significant drop. Would you say cyl 1 injector is working properly and 234 are possibly leaking causing an insignificant drop or the other way around. Thoughts?
- Jalvrzjn
5 years 6 months ago - 5 years 6 months ago #48668
by Jalvrzjn
Update. So I Teed in a fuel pressure gauge on the low side and found the fuel pressure dropping about 1 psi every few minutes. I unbolted the high pressure pump. Lifted it above the valve cover with the hard line still hooked up. Could see fuel slowly seaping out of the pump. Had to look closely and clean before. I can imagine the leak being more aggressive when the engine is running.
Last edit: 5 years 6 months ago by Jalvrzjn.
The following user(s) said Thank You: Tyler, Andy.MacFadyen
5 years 5 months ago #48725
Replied by Tyler on topic 2016 Sonata P0172
Nice.
Thanks for getting back to us with an update! I imagine it wouldn't take long to thin the oil out at that rate.
