Golf MK4 Startt but no COM with the ECM.
  • RimmersTechSWE
  • RimmersTechSWE's Avatar Topic Author
5 years 6 months ago - 5 years 6 months ago #48405 by RimmersTechSWE
Golf MK4 Startt but no COM with the ECM. was created by RimmersTechSWE
I'm helping out a neighbour with his Golf mk4. It starts and runs and communicates with all modules other than the ecm,
This leads me to believe the ECM communication portion is malfunctioning. Does anybody have any similar experiences in general or with VW K-line (no can diag) vehicles in particular?
2003
VW Golf MK IV
Engine 1,6 Gas (BCB)
ECM P/N 036906034DR
Regards
Mathias
Last edit: 5 years 6 months ago by RimmersTechSWE. Reason: Adding Vehicle info
5 years 6 months ago #48467 by Ben
does this have an aftermarket radio? apparently thats a common place for a short on the k line but I believe it takes down the whole network. what scan tool is being used? ive had com problems that were specific to scan tools and using another brand tool would communicate without issues. :dry: looking at you launch...
The following user(s) said Thank You: Andy.MacFadyen, RimmersTechSWE
5 years 6 months ago - 5 years 6 months ago #48475 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Golf MK4 Startt but no COM with the ECM.
Beat me to it on the aftermarket radio -- also check power and both grounds on the 16 pin socket.
Last edit: 5 years 6 months ago by Andy.MacFadyen.
The following user(s) said Thank You: RimmersTechSWE
  • RimmersTechSWE
5 years 6 months ago #48477 by RimmersTechSWE
Replied by RimmersTechSWE on topic Golf MK4 Startt but no COM with the ECM.
I used a delphi/autocom but now I also have a VCDS lite that I can use. I will try again as soon as I have access to the car again. Thanks, I don't think it even has a radio but if it does its aftermarket.
  • RimmersTechSWE
5 years 6 months ago #48490 by RimmersTechSWE
I will but I'm pretty sure they work since all the other modules respond OK.
  • RimmersTechSWE
5 years 6 months ago #48527 by RimmersTechSWE
Thanks.
I have now tried scanning the car with and without the aftermarked blaupunkt stereo installed and still no luck in communicating with the ECM. This time I used vcds and it communicates with the cluster and other miscellaneous modules. I have a used ECU coming in by mail that I can recode for this car .
VCDS displays an error that says it cant sync with the ECM.
