Nissan
  • Flako76
  • Flako76's Avatar Topic Author
5 years 6 months ago #48421 by Flako76
Nissan was created by Flako76
P0101 code on nissan altima. How to fix?
5 years 6 months ago #48426 by Tutti57
Replied by Tutti57 on topic Re:Nissan
Hello, what year altima is it? 4 cyl or v6?
Look at FFD and see what RPM the code set. Also check the fuel trims when it set.
There is a bulletin for a lot of them if there are no driveability issues. That one is an ecm update.
This code can be a number of things, but is usually not a failed maf sensor, if it's the only code. If it set at idle in freeze frame, it's most commonly a dirty throttle body if the air intake ducting is intact and the airbox is sealed properly.
It can also be a vacuum or exhaust leak, so check your fuel trims.
The following user(s) said Thank You: John Curtis
