Reading OBD "1.5" codes
  • AJeep18
  • AJeep18's Avatar Topic Author
5 years 6 months ago #48589 by AJeep18
Reading OBD "1.5" codes was created by AJeep18
Currently working on a 1995 Buick and trying to read the trouble codes. From what I understand it is an OBD 1 system, going by the year, but it definitely has an OBDII plug... My cheapo code reader just says error. Can I short the pins and get the light to blink? Any thoughts appreciated!
5 years 6 months ago #48590 by Ben
Replied by Ben on topic Re:Reading OBD "1.5" codes
Some 95 vehicles had implemented obd2. I would not try to short terminals try a different scan tool
5 years 6 months ago #48591 by Ben
Also check power and ground on dlc
5 years 6 months ago #48594 by Hardtopdr2
Replied by Hardtopdr2 on topic Re:Reading OBD "1.5" codes
You will either need to buy the special adapter for obd 1.5 or make one by googling obd 1.5. A different scan tool will not work in this case.
5 years 6 months ago - 5 years 6 months ago #48597 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Reading OBD "1.5" codes
ISTR Ivan on the Pine Hollow Auto Diagnostic Channel did a comparision trial on using Autel, Launch and Snap-on on a 92 GM OBD1.5
Last edit: 5 years 6 months ago by Andy.MacFadyen.
  • AJeep18
5 years 5 months ago #48727 by AJeep18
Replied by AJeep18 on topic Reading OBD "1.5" codes
Well, as it turns out my Bosch 525 was able to read the codes! It obviously was not able to auto ID it but, I was able to manually enter it. For some reason the first time it wasn't able to connect and read the code but I tried again and it did work!
Time to create page: 0.267 seconds
