2008 Chevrolet Impala 3.9L
  • Joecool
  • Joecool's Avatar Topic Author
5 years 6 months ago #48639 by Joecool
2008 Chevrolet Impala 3.9L was created by Joecool
Hello, I have a 2008 impala with the 3.9L engine.the car runs rough on idle and has a code of no correlation cam & crank . As soon as I supply power to the cmp actuator the car idles normal.already check cam and crank sensor.thanks in advance
  • Joecool
5 years 5 months ago #48733 by Joecool
Replied by Joecool on topic 2008 Chevrolet Impala 3.9L
Yes I’m missing power to the cmp actuator,as soon as I supply power to the actuator the engine idles as it should.
  • Joecool
5 years 5 months ago #48735 by Joecool
Oil level is good ,was change a week ago 10w30, I’ve check for an open an it show 0 ohms which indicated no open. I’ve try commanding the actuator on with my scanner but for some reason it won’t allow the test to run, I’m thinking is due to the cam & crank correlation code.i will definitely check oil pressure.
  • Joecool
5 years 5 months ago #48736 by Joecool
I forgot to mention I did hook up my o scope to the brown wire and no activity
5 years 5 months ago #48774 by Ben
Replied by Ben on topic Re:2008 Chevrolet Impala 3.9L
The pcm won't control actuator with a correlation code. supplying power to the actuator should make it run badly, I suspicion you have jumped time and phasing the cam all the way bring it back in time
