2007 GMC Acadia canbus problem
  • jerry r
  • jerry r's Avatar Topic Author
5 years 5 months ago - 5 years 5 months ago #48747 by jerry r
2007 GMC Acadia canbus problem was created by jerry r
2007Acadia with a canbus problem, traction light stability light off and problem on the DIC, intermittently , communication with scan tool ,dtc u2100 ohms 52.1 which is a little low. my question is can anybody give me direction on what the possible meaning of this waveform thank you?
Last edit: 5 years 5 months ago by jerry r.
5 years 5 months ago #48755 by Tyler
Replied by Tyler on topic 2007 GMC Acadia canbus problem
jerry r, let's back up a second. Which module is setting the U2100, specifically? The EBCM?
Your thread title says 2007, but the message says 2017. U2100 is a possible DTC on both.
Where did you take your 52.1 ohm measurement? 6/14 at the DLC? Was the problem happening while that measurement and your waveform were taken?
  • jerry r
5 years 5 months ago - 5 years 5 months ago #48756 by jerry r
Replied by jerry r on topic 2007 GMC Acadia canbus problem
It's a 2007 the dtc is on the bcm and ecbm resistance test between 6/14 checked with battery unhooked,waveform tooken at 6/14 vehicle running
5 years 5 months ago #48757 by Matt T
Replied by Matt T on topic 2007 GMC Acadia canbus problem
I'm wondering if that sine wave in your channel settings means the 'scope is set to AC instead of DC??
5 years 5 months ago #48758 by Dtnel
Replied by Dtnel on topic 2007 GMC Acadia canbus problem
Trying to reply from laptop with a link copy/paste but don't know why it won't allow me to right click and paste or other paste methods. Any clue as to why this occurs even on mobile browsers as well @Tyler
5 years 5 months ago #48759 by Matt T
Dtnel wrote: Trying to reply from laptop with a link copy/paste but don't know why it won't allow me to right click and paste or other paste methods. Any clue as to why this occurs even on mobile browsers as well @Tyler
The website disables right click when you're logged in. If I want to copy text or images from a thread I open it in a private window. Copy and pasting when replying I use keyboard shortcuts.
  • jerry r
5 years 5 months ago #48760 by jerry r
It's on DC this is happening intermittently
5 years 5 months ago #48761 by Tyler
Matt T nailed it. It's a spam control feature built into Kunena. It's annoying, we know. :(
5 years 5 months ago #48762 by jreardon
Replied by jreardon on topic 2007 GMC Acadia canbus problem
Keith Perkins in his youtube video Diagnostic Process Round Table mentions he doesn't like anything less than 54 ohms so maybe start with that. The resistors are in ECM and the Transfer Case Shift Module or if you don't have that, a standalone resistor hanging out of the harness. Might as well just pull the AWD (transfer case) fuse 15A in the underhood fuse block and work through each module on the canbus, killing power, to shut them up lol.
5 years 5 months ago #48764 by Dtnel
See if this video I stumbled across the other day can help you. He laid it out in layman terms & pretty good for a young guy to boot.
My top 3 forums / Channels / Websites I subscribe to are,
www.scannerdanner.com/forum.html
ScannerDanner Premium Home Page, www.scannerdanner.com/scannerdanner-premium-chapters.html . I've been a satisfied member for 3 1/2 years myself (Dec 2017)
www.l1training.com/free-training/
www.tstseminars.org/home
TST Training Menu = www.tstseminars.org/plans-pricing
If you subscribe to all 3 and use YouTube as a supplement you can get the most up to date information in regards to testing methods, latest training.
Note on the TST one they added a annual membership late last year after I'd requested because they'd only do monthly prior but I'd mentioned that for mechanics for example it would be a great gift year round. This is what they came up with. The TST annual membership for $99 + the TechFlix Videos they produce which are about as basic as they get as in production. So both of those you can get for $174~175 yrly then, ScannerDanner Premium had the monthly Subscription which you're getting all Paul's content from before and now all the Added Bonus "Caleb" content which is Paul's newer videos plus the bonus one's mentioned that are done by his Son Caleb which he's been killing it with. With Keith Perkins over @ L1 Diagnostics & Programming he's covering alot of what others aren't addressing. Alot of his content you won't just find "Anywhere"
All of these websites have a FREE TRIAL. You really can't go wrong as I say. Less than $500 per yr give or take a little bit.
5 years 5 months ago #48765 by Dtnel
Bothe of those waveforms were on the High / Low Can Bus Channels? The reason I ask is you'll have networks that do the same thing at times and the waveforms will be identical showing they're communicating properly.
Did this have a code? GM Traction Control, Service 4ed lights have always been a "normal" visitor. I chased one a few years ago on my 2004 Tahoe with Code, thought it was the Switch after checking wiring, harness plugs, transfer case shift motor. Swapped the switch, ran fine for a couple years
  • jerry r
5 years 5 months ago - 5 years 5 months ago #48766 by jerry r
Yes on low and high can I checked before on this vehicle and they were mirrored each other not identical ,6/14 on dlc
5 years 5 months ago #48767 by Cheryl
Replied by Cheryl on topic 2007 GMC Acadia canbus problem
Yea that waveform doesn’t mirror each other. More like there almost the same both go high both go low.
5 years 5 months ago #48768 by Cheryl
What modules do you lose communication with when the waveform looks like that? The whole can bus or just one module?
  • jerry r
5 years 5 months ago #48769 by jerry r
Everything the whole bus vehicle still starts but acts like it's misfiring,and gauges go a little crazy when I hook up the scanner when there's no communication koef
5 years 5 months ago #48770 by Cheryl
Yea you might want to pull power to one module at a time. Or unplug module use jumper wires to jump com lines coming in and going out of module.
