ford explorer 2006 running rich and no codes
- Electricsanti22
5 years 5 months ago #49196
by Electricsanti22
ford explorer 2006 running rich and no codes was created by Electricsanti22
the vehicle has been stationary for 3 months and i decided to replace fuel injector fuel fiter and ect sensor and is running rich with no codes and black smoke rough idle and before all of this it was running normal without any problem.. i checked ect sensor with thermometer and temp is similar to ect sensor. i suspecting now the new fuel injectors which i took some waveforms so u guys giveme some directions on this. i appreciate it
- Cheryl
- Thank you received: 215
5 years 5 months ago #49200
by Cheryl
Replied by Cheryl on topic ford explorer 2006 running rich and no codes
What does ect read on scanner in temperature?
- jreardon
- Thank you received: 198
5 years 5 months ago #49201
by jreardon
Replied by jreardon on topic ford explorer 2006 running rich and no codes
Did you change out all the injectors? Because at least one has almost double the current draw.
Can you retake capture with more time on the screen I would like to see 2 yellow voltage spikes and all the current humps between them.
Is there a bank to bank fuel trim imbalance?
That's the only way I can explain the injector pulse width difference on that other injector.
- jreardon
5 years 5 months ago #49202
by jreardon
Plus, that really short injector pulse width one has no sign of pintle hump. Maybe it was too fast and the injector never had enough time to open.
The long duration one, that definitely has a hump.
- Electricsanti22
5 years 5 months ago #49204
by Electricsanti22
Replied by Electricsanti22 on topic ford explorer 2006 running rich and no codes
I checked againg and looks like the long one is intermiten closed as in this capture correctme if am wrong
- Electricsanti22
5 years 5 months ago #49205
by Electricsanti22
it reads 187 f on scanner and 182 f thermometer when is warne up
- jreardon
5 years 5 months ago #49206
by jreardon
Injectors should be firing sequentially, not simultaneously and not the same injector twice over. It seems like a good idea to check your cam and crank signals.
- Electricsanti22
5 years 5 months ago #49209
by Electricsanti22
idont know man i am really suspectings injectors since they were cheap 49 dllrs for allof them they were bosch on ebay
