2011 gmc terrain 2.4
  • Indyvike
  • Indyvike's Avatar Topic Author
5 years 5 months ago #49208 by Indyvike
2011 gmc terrain 2.4 was created by Indyvike
My wife's was driving her terrain about 3 miles, it started chugging and died wont restart.
codes present P00CA,P00C8,P0090,P0092.
It start run about 30 seconds in that time fuel stayed around 64 psi. Since my scan tool won't flash fuel pump control module i got high pressure fuel pump still won't start.. Can you give any tips. Also key on 12 volts to high pressure pump.. Thank you
5 years 5 months ago #49211 by Tyler
Replied by Tyler on topic 2011 gmc terrain 2.4
All those codes are related to a circuit high condition in the high fuel pressure regulator circuit.
With the key on and the engine off, backprobe one high fuel pressure regulator pin at a time and take a voltage reading with the meter grounded to B-. What are your voltage readings on both wires?
  • Indyvike
5 years 5 months ago #49265 by Indyvike
Replied by Indyvike on topic 2011 gmc terrain 2.4
Purple wire 7.35
Yellow wire 7.36
Battery voltage 12.41
It will run on starting fluid.
Thank you for any help.
5 years 5 months ago #49281 by Tyler
Looking good so far. I took some known good readings off an '11 Equinox. Same engine.
Now, KOEO, disconnect the pump connector and recheck voltage on both wires. Should have 12V on the yellow, and 0V on the purple. The 12V on the yellow should NOT be able to light a test light connected to B-.
  • Indyvike
5 years 5 months ago #49295 by Indyvike
KOEO
purple .006 v
yellow 11.91 v
battery voltage 12.19
5 years 5 months ago #49296 by Tyler
Looking good to me. :cheer: Those readings match my known good exactly.
Can you measure high pressure fuel pump resistance? Connector unplugged, across both pins. I don't have a spec available at the moment - I'd expect five ohms or less.
  • Indyvike
5 years 5 months ago #49297 by Indyvike
The one i replaced was 9.8 ohms, the new one was 9.4. I read somewhere spec was 9-11 ohms.
  • Indyvike
5 years 5 months ago #49298 by Indyvike
Something is not allowing high pressure fuel pump to run, when I use starting fluid it idles at only 62 to 66 psi fuel pressure. Which is about the same as KOEO.
5 years 5 months ago #49300 by Blazerguy2020
Replied by Blazerguy2020 on topic 2011 gmc terrain 2.4
Did you erase the codes after you replaced the high pressure fuel pump and they immediately came back?
  • Indyvike
5 years 5 months ago #49309 by Indyvike
Kind of odd tried to erase, It said permanent they wouldn't erase. But I only have otc 3111. Going to get a launch or autel as soon as I decide on which one.
5 years 5 months ago #49312 by Blazerguy2020
Try unhooking the battery for an hour or so
  • Indyvike
5 years 5 months ago #49331 by Indyvike
Tried that codes still present. I think permanent codes have to cleared through drive cycle.
