2008 dodge grand caravan 3.8
  • autojoe
5 years 4 months ago #49382 by autojoe
2008 dodge grand caravan 3.8 was created by autojoe
What would cause limp mode not above 25 mph. Pcm or tcm?
5 years 4 months ago #49384 by Ben
Replied by Ben on topic Re:2008 dodge grand caravan 3.8
This applies to most vehicles Transmission limp mode locks in 2nd or 3rd gear (the transmission will not shift)it will slip pretty bad taking off from a start (engine rpms easily raising without a noticeable raise in speed) may slip badly the whole time depending on Transmission damage, typically able to achieve 45+ mph in trans limp mode .
Engine limp mode or reduced power mode usually has very limited throttle response and limited throttle angle so winding the vehicle out or getting above 25mph is much more difficult and is often accompanied by red electric bolt symbol on the dash and some vehicles display reduced power mode on instrument cluster
The following user(s) said Thank You: autojoe
