BPW(ms) data PID meaning?!?
- bigdaddy24
5 years 5 months ago #49301
by bigdaddy24
BPW(ms) data PID meaning?!? was created by bigdaddy24
Hi all, I have searched high and low on the internet for the meaning of this data pids name, I have a 94 firebird lt1 and my snap on verus shows a left and right BPW(ms) data pid, the only acronym I can find is break pulse modulation but the pid kinda is similar to my rpm pid, anyone know what this means? obd1
- AJeep18
- Thank you received: 34
5 years 5 months ago #49302
by AJeep18
Replied by AJeep18 on topic BPW(ms) data PID meaning?!?
Base Pulse Width (milliseconds)?
GM: Base Pulse Width (BPW)Ideally, n = PV /RT and then injector pulse = n / injector flow constantGM introduce the concept of “Base Pulse Width” or BPW to reduce the “V” and “R” terms. Basically, the BPW is how long the injectors need to be open in order to fill cylinders at 100% volumetric efficiency at a standardized temperature. The BPW is then multiplied by the Volumetric Efficiency table (which is no longer a VE table in the ideal sense of the word) to determine fueling at different load and RPM conditions. This is then modified further by coolant and intake air correction tables to account for temperature. This cuts the number of math operations more or less in half. The idea behind Speed-Density is being applied in a way that is less math-intensive.
- AJeep18
5 years 5 months ago #49303
by AJeep18
support.moates.net/theory-pulsewidth-system/Base Pulse Width (milliseconds)?
5 years 4 months ago - 5 years 4 months ago #49388
Replied by Andy.MacFadyen on topic BPW(ms) data PID meaning?!?
Great solid info A Jeep18
Moving topic to repairs section
Last edit: 5 years 4 months ago by Andy.MacFadyen.
5 years 4 months ago #49389
Welcome to the Forum bigdaddy24 good to have you here.
Moving your question to repairs section.
- bigdaddy24
5 years 4 months ago #49394
by bigdaddy24
Replied by bigdaddy24 on topic BPW(ms) data PID meaning?!?
Thank you so much for the info! Can't believe I couldn't put 2 and 2 together, thank you for moving!
