AC clutch rubbing against Compressor
  • JROB27
  • JROB27's Avatar Topic Author
5 years 4 months ago #49417 by JROB27
AC clutch rubbing against Compressor was created by JROB27
I have a 2001 Toyota Tacoma where the AC clutch is rubbing against the compressor when the AC is turned off. I have a short somewhere because the 10 amp ac fuse keeps blowing. Following the diagram that fuse powers the AC control system and AC pressure switch. I ohmed the magnetic clutch and it was around .5- 1.1 ohms
5 years 4 months ago - 5 years 4 months ago #49420 by jreardon
Replied by jreardon on topic AC clutch rubbing against Compressor
using ohms law, 12.6 volts divided by .5 ohms comes to 25.2 amps. That's too much!. Unplug the clutch and take measurement there, if you still read that low, then replace the clutch.
Last edit: 5 years 4 months ago by jreardon.
5 years 4 months ago #49443 by Tyler
Replied by Tyler on topic AC clutch rubbing against Compressor
I agree with jreardon, your resistance measurement is too low. Most A/C clutches draw two to three amps. That works out to around four ohms, give or take.
