Damn, P0300 back. again
- JonnyR
P0300 code, A few random misfires ONLY at idle! Raise RPMs, snap throttle, all good. Misfires go to zero on all cylinders! Car is performing great on a drive.... Tried so many tests, I'm dizzy. Any and all assistance would be most appreciated. Give me a shout, regards to all.....
- juergen.scholl
- Active partschanger
- Thank you received: 462
it will be helpful to provide more information about the coditions when misfires occure.. . engine cold, hot, always?? Fuel trims, O2 etc...
Did you check mode 6 data, you might be able to identify specific cilinder(s).
Based on your idle observation you may or may not have a valve issue, a cylinder leakage test or a pressure transducer most probably will find out.
What actual tests do you have performed?
undefined I do strive to be a better "tech" everyday, though! My abilities are improving with diagnosing, but I have a lot more schooling to go!
Welcome to the club! :silly:
Which cylinders had counts, specifically? Which scan tool are you using? I agree with Juergen that an intake leak or valve issue is likely based on your description.
I have seen GM vehicles set false p0300 when a cam/crank relearn needs to be done with the scan tool.
- JonnyR
P0300 code back after the 4th or 5th ignition cycle. thanks for the help, could sure use any/ all assistance with this one!
- JonnyR
- JonnyR
- JonnyR
- JonnyR
All grounds checked, entire ignition system checked and fresh plugs, wires components replaced. Plugs look as they should, light tan color, no fouling, arcing etc.
The code has been since I limped this bad boy home. Still comes and goes. No apparent felt misfires, runs and sounds like a new car.
Could it be all because the last few calibration upgrades were never done, from GM? Car ECM?
All replies, appreciated
- JonnyR
- JonnyR
- juergen.scholl
Depending on when the ecm was updated the last time I don't consider this to be high onthe list.You may want to look up which issues newer calibrations (than yours...) actually do address.
- JonnyR
THX for responding!
