A/C Diag - 2013 Chevy Equinox LT
- Archer
5 years 4 months ago #49695
by Archer
A/C Diag - 2013 Chevy Equinox LT was created by Archer
Hello everyone,
I could use some help on an A/C diag for a 2013 Chevy Equinox with AWD and a V6. Another tech diagnosed it as needing the works - compressor, condenser, drier and a new shrader valve for the high side port. Its all back together now, and the cooling fans will not kick on unless I jump the load side of the relay. To the best of his knowledge, he recalls the fans working properly prior to the repair. The A/C still blows hot, even though the compressor kicks on.
Any thoughts on where to go from here?
- Ben
- Thank you received: 215
5 years 4 months ago #49700
by Ben
Replied by Ben on topic Re:A/C Diag - 2013 Chevy Equinox LT
What are your high and low side pressures? do they fluctuate? Do they run the low side down to under 20 psi after a minute ? Does the condenser get hot?
- Hardtopdr2
- Thank you received: 150
5 years 4 months ago #49702
by Hardtopdr2
Replied by Hardtopdr2 on topic A/C Diag - 2013 Chevy Equinox LT
did he replace orifice tube and look at h block? Were there any dtcs for temp blend door actuators or actuator counts not matching normal travel counts? did he inspect for rodent nests in temp flap area? what are pressures when it is running with compressor on? does high side go really high and low side go really low/vac? did he flush ac lines if it had "the black death" ? or replace those as well?
- Archer
5 years 4 months ago - 5 years 4 months ago #49718
by Archer
Replied by Archer on topic A/C Diag - 2013 Chevy Equinox LT
I don't know if the orifice tube was replaced or if the lines were flushed. The condenser is not heating up at all. No DTC's except for a permanent Cooling Fan Control Circuit code. Static pressures are 38 (low) and 100 (high) and running they are 26 (low) and 105 (high). The pressures do not fluctuate beyond that.
The blend doors also seem to be operating properly, but that's purely from a visual inspection.
Thank you all so much for your help!
Last edit: 5 years 4 months ago by Archer.
- Hardtopdr2
5 years 4 months ago #49721
by Hardtopdr2
As it looks with the pressures you have you are under charged. I am busy right now but let me see what I can find out
5 years 4 months ago #49722
Replied by Tyler on topic A/C Diag - 2013 Chevy Equinox LT
The high side pressure isn't high enough to made the PCM activate the fans. That'd be why they aren't coming on.
In the HVAC module, what's the compressor solenoid actual current?
- Archer
5 years 4 months ago #49730
by Archer
Unfortunately, the shop I work for seems to be more interested in selling parts than diag time so I wasn't able to check voltage at the HVAC module. They put another tech on it this morning and he threw the expansion block at it and it seems to have fixed the issue.
As far as pressures, the only info I've been able to find was a chart in one of the videos from Ratchets and Wrenches on YouTube. According to that, with the ambient temp around 80 F and humidity above 60%, the low side should have been between 27 - 42psi and the high side should have been between 128 - 181psi.
Thank you both for the help!
