1995 Chevy Astro
- Cheryl
- Thank you received: 215
5 years 4 months ago #49696
by Cheryl
1995 Chevy Astro was created by Cheryl
Looking at block integrator and block learn they are at 150 at idle and come closer to 128 at 2500 rpm. It runs bad. Map sensor reads 1.5 volts at idle. Coolant temp sensor reads correctly. Egr valve not stuck open. What is the running fuel pressure spec you guys have from experience? I’m at 49 psi at idle.
5 years 4 months ago #49697
Replied by Chad on topic 1995 Chevy Astro
Spec is:
1. Ignition "OFF" for 10 Seconds.
2. With ignition "ON," engine "OFF" and fuel pump running, pressure should be 380-420 kPa (55-61 psi).
- Cheryl
5 years 4 months ago #49698
by Cheryl
Replied by Cheryl on topic 1995 Chevy Astro
I only get 52 at the fuel pump prime
- Cheryl
5 years 4 months ago #49699
by Cheryl
It doesn’t bleed off instantly or anything. I might be on the wrong track with going after fuel
