faulty ignition
- Fino
5 years 3 months ago #50044
by Fino
faulty ignition was created by Fino
hello I am Fino from Mauritius, very glad to make part of your group.
I like very much diy.in various fields.
Having difficulties to close the doors of my VW Bora 2000 (1399cc petrol engine nu ahw302414), I decided to open the panel of the driver's door. Having found nothing suspect. After this operation, the car start and shut down after one or two seconds.
I have good sparks, injectors clean, pump ok.
I have no wiring diagrams, can anyone helps me in the following step to take.
Hoping to hear soon good advice, thanks a lot in advance
- juergen.scholl
- Active partschanger
- Thank you received: 462
5 years 3 months ago - 5 years 3 months ago #50099
by juergen.scholl
Replied by juergen.scholl on topic faulty ignition
Fino,
when the car shuts down after a couple of seconds this may be an immobilizer issue. Does the key symbol in the dash go out when you open the switch or does it stay on. Do you have a second key (programmed) you can try to start the car?
Last edit: 5 years 3 months ago by juergen.scholl.
- Fino
5 years 3 months ago #50107
by Fino
Replied by Fino on topic faulty ignition
Hye thanks you very much for your reply
I have only one key .
The key symbol stay on when switch is on ,
A private key manufactuer put it on test and told that the key is ok .
In this case shall i do the five volts check ?
If yes the switch must be on or off ?
thank you very much for my first reply .
- juergen.scholl
5 years 3 months ago - 5 years 3 months ago #50108
by juergen.scholl
When the key symbol stays on thhen the key is NOT recognized and there is no start permisson!
The key may be good but the antenna could be bad, a wire might be broken.......there are many possibilities.
With a capable scanner -VCDS, Launch, Autel etc, you can enter address 17 - instrument cluster. The immobilizer is part of the cluster and MVB 21 to 24 will show you information on this system.
If you´re not familiar with immobilizers and how they work it may be easier to contact a locksmith. On this car it is easy to erase the immobilizer, manipulating the ecm.
- Fino
5 years 3 months ago #50117
by Fino
Good morning thanks for your reply .
In the mean time waiting for the vcds , how can i test if the antenna is functionning?
Also where can i get a wiring diagram ?,
On two sensor the 5 volts is missing ,
Thank you very much for very precious advice ,
- chief eaglebear
- Thank you received: 70
5 years 3 months ago #50118
by chief eaglebear
Replied by chief eaglebear on topic faulty ignition
hi fino whats your fuel pressure
- Fino
5 years 3 months ago #50124
by Fino
Hi good evening thanks for your reply .
I have no instrument for measuring the fuel pressure but i can hear the pump switch on
I also already clean the injectors .
Thank you very much hoping to hear from you soon .
- Fino
5 years 2 months ago - 5 years 2 months ago #50569
by Fino
Hello everybody sorry to bother still with my vw bora that won't start.
With the negative pole of the battery disconnect one side of the test light on battery negative and the other side to the floating negative wire the test light turn's on,
voltage check in between the negative of the battery and the negative floating wire 12;76 volts
same voltage on fuses 12 ; 13; 14; 15, 16; 41, 42
but 0;49 volt on fuse 5;6;7;9;11and 29
And finally zero voltage and no light on fuse 1, 2, 3, 4, 18, 19, 20, 21, 22, 23, 24, 25, 26, 29, 34;and 48
It seem like a short to ground (correct me if i am wrong).
Sometimes the fuel pump have voltage and sometimes no
I would like to disconnect and clean all the ground wire on the body and then reconnect one by one with voltage or testlight check
Is this good for the computer ?
All suggestions are welcome. Thanks a lot;
Last edit: 5 years 2 months ago by Fino. Reason: faulty ignition
