1996 tacoma,2.7
  • Herc53
  • Herc53's Avatar Topic Author
5 years 3 months ago #50182 by Herc53
1996 tacoma,2.7 was created by Herc53
ok,I'm back working on my 1996 tacoma. I pulled motor back out. Checked reluctor ring.no problems,I installed a OEM crank sensor. $ 197.00 from Toyota a dealer.
I'm seeing rpms on my computer.I had head reworked. I've got everything together. I tested fuel  pump ohms,good (3.7)I've tested circuit relay,good,i tested,efi relay good. I finally got me a FSM  and i slipped up on this thing called a ignitor relay noise filter,etc. . If this thing goes bad will it cause a no start ? I really  don't know how to test it. However it has no continuity and no ohms . So i think it's bad. Nothing in my FSM tells me anything about this creature.My computer tells me i have an ignitor problem.DTC 1300 . I have fuel pressure(50+ lbs) once i spin engine over..I've got a new Distributor and ignitor to put in. Haven't put in yet .I had trouble putting the old distributor in,until late. I figured how to put #1 on compression stroke align mark on distributor with mark on gear in 12:00 postion ,slide it in and the rotor  will roll clockwise toward #1 about 2:oclock position once it's butts up to head.I"m in for the long haul. it's got to go. I appreciate all of you thats helped me .I just need a little more
