2011 Chevy Cruze w/1.8l engine (Codepalooza)
In diagnosing this problem I believe I've shorted out body control module. Pictures to follow, have an idea of where to start. Not sure where to start. Thinking Body Control Module.
The BCM? :huh: Why, because of the U0140? Or, are there new symptoms now?
Clear ALL codes and see who comes back.
- Richard6767
- Thank you received: 4
Because it takes some driving and sets a plausibility code leads me to believe that the tone wheel has debris or damage or some similar fault. Possibly even rust/corrosion jacking under the sensor effecting the air gap.
In any case, without ABS data, you are left with little troubleshooting ability unfortunately, beyond what the code set conditions can tell us.
As far as injecting voltage from an external power source (if I'm reading your post correctly) like a jump pack: 1) I wouldn't
2) even if you poke every wire with the positive lead of the jumper, if it's just sitting on the floor it's not part of the circuit. Any bypass testing must be done using the cars own power and ground
From GM SI:
Note: If any of the symptom codes 0F, 18 or 5A are set, refer to the Diagnostic Fault Information table for possible mechanical faults or conditions.
- Richard6767
With this information that you sent me I feel confident about getting the hub from RockAuto.
Sweet.
- Richard6767
- Richard6767
Question on this topic. When I replace the hub will I be able to bleed the brakes conventional style, clear the code and let the computer relearn since my Innova doesn’t have ABS bleed option?
I don't think you'll need to bleed the brakes? :huh: If it's rear drum, the hub assembly should come out without removing the wheel cylinder or hardware. Bleeding won't be necessary unless the backing plate is frozen on the hub. If it's rear disc, just unbolt the caliper and hang it out of the way.
- Richard6767
I always just left the line and WSS installed? :silly: But that may not be possible for you depending on how crusty the hub and backing plate are.
If you do have to take the wheel cylinder line off, no big deal. Cap the line while you're working to stop fluid loss. I like these little MityVac plug sets, but you can use whatever is handy.
www.amazon.com/Mityvac-MVA6004-Vacuum-Line-Cap/dp/B007TMSNYM
When you've got everything reassembled, just bleed the brakes like normal using the bleeder screw. As long as you get the air out, and you didn't run the master cylinder dry, you're golden.
If you use a rod or something to depress the brake pedal about halfway down before you crack a brake line, it won't drip.
You will kill the battery with the brake lights if you don't disable them however;)
This won't get you out of having to bleed the brakes, just keeps the job a little cleaner.
- Matt T
- Thank you received: 276
Lisle hood prop works good for holding down brake and clutch pedals. Mine spends more time doing that than holding hoods up :lol:
- Richard6767
After several attempts got hub out and replaced. My ABS light is finally off. I'll try to upload picture of old hub.
Nice! Well done.
- Richard6767
Now for (Codepalooza). Starting at the top. Engine Control Module; P2076-00 common answer is replace intake manifold.
Fuel Pump Control Module(1); U0073-00 Control Module Communication Bus A Off.
Electronic Brake Control Module(1); U0140-71 Lost Communication With Body Control Module.
Multi-Axis Acceleration Sensor Module(1); U0121-00 Lost Communication With Electronic Brake Control Module.
Steering Wheel Angle Sensor Module(1); U0121-00 Lost Communication With Electronic Brake Control Module.
Body Control Module(3); B2750-02 Horn Relay Secondary Circuit, Short to Ground. B3875-04 Windshield Wiper High Speed Relay Circuit, Open. U0164-00 Lost Communication With HVAC Control Module.
Inflatable Restraint Sensing And Diagnostic Module(3); B1325-03 Control Module Power Circuit, Low Voltage. U0140-00 Lost Communication With Body Control Module. U0073-00 CAN Bus Communication.
Radio(2);U0020-00 Low Speed CAN Bus. B1020-00 Auxiliary Electronic Control Module.
Remote Heater And Air Conditioning Control Module(2); B0233-01Air Flow Control Circuit, Short to Battery. B0408-01 Main Temperature Control Circuit, Short to Battery. All this information comes from my Thinkscan Max. Correct me if I’m wrong but by typing all this in, it seems like my focus should be on the Body Control Module. If I’m right should I start at the connector?
If there is no symptoms or warning lamps I would shut the hood and call it good.
It's really not uncommon for modules to set communication codes even if there is nothing wrong with the car.
- Richard6767
