System too rich bank 1
- Devin0789
5 years 2 months ago #50622
by Devin0789
System too rich bank 1 was created by Devin0789
Hello all, new member and first time posting. I’m working on a 2011 Audi s4 3.0 supercharged. Getting a fault for system too rich bank1. I’d really like to test injectors on bank 1 and also verify the bank1 02 sensor is reading correctly. Is there a way to make the sensor go lean to make sure it’s fluctuating correctly? I do not own a scope at this time unfortunately. Open to any and all suggestions. Thanks
- jreardon
- Thank you received: 198
5 years 2 months ago #50623
by jreardon
Replied by jreardon on topic System too rich bank 1
Decel fuel cut off? Flutter the gas pedal, watch the rear o2 - if they go lean and the upstream stays rich, it's lying.
- Devin0789
5 years 2 months ago #50860
by Devin0789
Replied by Devin0789 on topic System too rich bank 1
Car has been fixed!!! Long story short, high pressure fuel pump was leaking fuel into oil. Scanner danner book would call it “fuel contaminated oil”.
What an incredible find!
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
5 years 2 months ago - 5 years 2 months ago #50880
by VegasJAK
Replied by VegasJAK on topic System too rich bank 1
This is what drive diagnostician crazy. A bank specific code which turns out to be a global variable. A malfunctioning fuel pump dumping fuel into the crankcase would produce a rich condition for both banks on a V engine. Could be in this case bank 1 set the code first. Bank 2 was probably close to setting a code as well?
A single cylinder with a leaking injector would set a bank specific code but the fuel from it washing into the crankcase would set a global code. Again, bank 1 set the code first.
Last edit: 5 years 2 months ago by VegasJAK.
- ScannerDanner
- Administrator
- Thank you received: 500
5 years 2 months ago #50893
by ScannerDanner
Don't be a parts changer!
Replied by ScannerDanner on topic System too rich bank 1
Just a quick thought. It may have been rich on both banks and only coded for one bank. This is a lesson on why we can't just look at the code we must verify the fuel trim numbers ourselves.
For example, I've seen many vacuum leaks flag only one bank while both had very positive numbers
