2005 Toyota Prado negitive 40 long term fuel trims
  • Byronica
  • Byronica's Avatar Topic Author
5 years 2 months ago #50735 by Byronica
Hi All
I have a 2005 120 series Toyota Landcruiser Prado with a 1grfe motor in the shop at the moment. it has -40 LTFT on both banks at idle. have checked all the normal suspects IE: TPS, MAF, fuel pressure and vacume. Driveableity issues are if you try to take off like a normal person IE; 1/4 -3/4 throttle it will bog really bad for 2-3 seconds till the STFT reaches +20 and then it will take off. The O2 sensors are switching correctly and have even removed and done a smother test to verify. When we remmoved the 02 sensors there was no sign of for over fueling. just for refrance i have put the values at idel below.
TPS .76V
MAF4.5 g/s
RPM 570
VACUME 25 inHG
Fuel pressure 43 PSI
Any help would be appreciated.
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
5 years 2 months ago #50748 by VegasJAK
I don't know about everyone else but I have to ask, what is a "smother" test on an 02 sensor?
  • Byronica
5 years 2 months ago #50764 by Byronica
Smother test is where with the vehicle running and O2 sensors at operating temp you remove them from the exhaust and while watching live data you get a rag with a hydrocarbon on it ie petrol or shallite and smothe th O2 and watch it switch from + to- to confirm that it is not biving a false signal
  • VegasJAK
  • VegasJAK's Avatar
5 years 2 months ago #50769 by VegasJAK
You can do this easier by pulling a vacuum line and seeing positive numbers and by introducing propane in the intake and seeing negative numbers.
  • VegasJAK
  • VegasJAK's Avatar
5 years 2 months ago #50826 by VegasJAK
What is your MAP sensor reading?
  • VegasJAK
  • VegasJAK's Avatar
5 years 2 months ago #50828 by VegasJAK
  • Byronica
5 years 2 months ago - 5 years 2 months ago #50832 by Byronica
true however when the LTFT is -40 the ecu is pulling so much fuel that even when you disconect the brake booster line it still will not go + ---- hence the smother test.
Last edit: 5 years 2 months ago by Byronica.
  • Byronica
5 years 2 months ago #50833 by Byronica
from all research and manules i have looked at it does not have a map sensor nor and egr
  • Byronica
5 years 2 months ago #51076 by Byronica
Problem solved.
First of all thanks to those who look and helped on this problem.
The problem was the injectors.
After exhausting all research i contacted the customer and explained that we had narrowed it down to 2 possibilities 1/ the ECU 2/ the injectors- how ever the 2nd option being unlikley as both banks were the same. it was at this point that the customer told me that they had put a set of injectors in a approx 100km ago
  needless to say i wasnt overly impressed as had asked multipule times what/if they had already done to the car.
and yes they were a cheap set of injectors off ebay.
now all i have to do is try and work out the bill..... thanks all.
