Scanner Readings
- Hardtopdr2
- Thank you received: 150
1. Coil should be looked at (ie ohm test the primary and secondary sides of coil) along with sparkplug gap. Also use a sparkplug tester to see if spark is good (a loud snap versus a dull tic sound) and bright blue and jumps a gap on the tester turned most of the way out.
2. Is compression test each cylinder when engine is cold and when engine is hot to see if some valves are sticking from carbon buildup. (South main auto has a video on a truck misfiring and lack of power going up hill albeit it was more intermittent than your situation but you never know) further more this will see if your timing chain might be the cause of the vacuum in exhaust as well
- Dinos55
Here are 2 samples of one is on the highway about 60MPH no issues running fine, Then the other one is as I was getting towards the top of the hill, however because of traffic I wasn't able to put the full load on it so it wasn't missing real bad, I will take another sample tomorrow hopefully under a bigger load creating the extreme miss to get a better picture of the sensor readings when it gets real bad.
Again thank you everyone that is giving me advise on the different possibilities.
- Hardtopdr2
- ontheriver
- Thank you received: 16
- Dinos55
Which CAT? I suspect your problem is on Bank 2.That test was done in front of the CAT, with the muffler disconnected.
- Dinos55
1: Driver & passenger side before CAT
2: Driver & passenger side after CAT
Same tests above but with the muffler detached ALL with the same results.
However I did get a code P430 when puling the hill and the truck was missing REAL bad. It's interesting I found an article about the P430 with the follow description that matches my issue to the letter T "see below"
If that is the case i guest I need to determine if its a bad sensor OR a bad CAT.
What is the best/easiest way to determine that?Here are the typical symptoms that something is wrong when you have code P0430. Often, when it is only the oxygen sensor is the issue, you’ll feel no symptoms at all.
- Mileage- May or may not suffer depending on how much or if the catalytic converter is clogged.
- Loss of Power– It is a really strange feeling to drive a vehicle with a catalytic converter that is going out. Typically, they’ll idle ok and drive normal under a light load. Whenever the engine is put under a heavy load it’ll feel like it is running out of gas. It’s very similar to the symptoms of a bad fuel filter .
- Service Engine Light– Often, this is the only symptom of the Chevy Silverado P0430 code.
- Dinos55
I am also uploading a few more graphs while going up the hill.
All three were captured at the same time
Oxygen sensors voltage Bank 1 Sensor 1 & 2 & RPM
Oxygen Sensors voltage Bank 2 Sensor 1 & 2 & RPM
Fuel Trim Bank 1
Fuel Trim Bank 2
At an idle in the driveway, seems somthing going on bank 2 sensor 2
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
There are two. Bank 2 Sensor 1 and Bank 2 Sensor 2.
Same for the capture on Bank 1.
I assume by the readings that the red is sensor 2 on each bank. I don't want to assume. If it's the red then bank 1 sensor 2 is reporting lean it should be up around 700mv steady. Bank 2 Sensor 2 is bad as it is oscillating. Should be steady at 700mv.
Something's up with the O2's. I know you bought new. Did you change both sensors 2? Or just sensors 1?
- Dinos55
If ever have a few Min. to let me pick your brain on a few questions I would love to talk with you.
Thanks!
Dean
- VegasJAK
- Dinos55
Thanks!
Dean
- VegasJAK
Do you have any propane?
- Dinos55
Thanks!
Dean
- VegasJAK
- Dinos55
Thanks!
Dean
- VegasJAK
I should never assume so I will say it, do the test with engine at full operating temp, 02's in closed loop and cats hot.
- VegasJAK
- Dinos55
Thanks!
Dean
- VegasJAK
What we're looking for is the pattern of the 02's as they return lean when you stop the peopane. The moment s1 drops lean note when S2 drops. Should be about 4-6 sec. You should see a noticable space in the pattern. I suspect bank1 will have a good space and bank2 will drop at the same time.
Post if you can.
