Misfire and smoke
- Devin0789
car shakes from cylinder misfire. Also has p0305 for cylinder 5 misfire. I swapped coil and plug with cylinder 7 and 5 and no difference. When unplugging coil connector on 5-8 the engine makes a difference. But when pulling coil harness for cylinder 4 there is no difference, makes me think the computer is wrong and it’s actually cylinder 4 that is a dead hole. Along with it, the car has a good amount of white smoke coming from exhaust. Open to all the help I can get. Thanks
- ScannerDanner
- Administrator
- Thank you received: 500
Don't be a parts changer!
- Devin0789
Bank 1 short term and long term was at 0.00.
Bank 2 short term is -7.7
Bank 2 long term is 0.00.
smoke smells like oil, no fuel smell at all. Thinking of performing compression check on cylinder 4…?
This is GDI engine if that makes a difference. Injectors are a huge pain to get to so if there are anyways of testing those without touching them that would be awesome. Thanks for the help
- Hardtopdr2
- Thank you received: 150
If it checks out ok smell oil to see if it smells like gas. Sometimes the gdi hi pressure pump seals will fail causing the oil in the pump to mix with fuel and spray into cylinders making a similar smoke (but not always).
A compression test would be the next step if all above are ok and then lastly checking intake valves for oil and carbon buildup from leaking valve stem oil seals.
My hunch is the turbo bearings went if that is the case you will need to replace the oil feed line along with flushing engine of oil coking deposits and lastly turbo assembly with gaskets.
Also check your cats as they will need cleaned out or replaced and exhaust manifold cleaned out.
- Devin0789
- Hardtopdr2
- Devin0789
- Hardtopdr2
- Devin0789
- Hardtopdr2
- Devin0789
- Devin0789
- guafa
- Thank you received: 80
So is definitely not related to fuel trim?
I mean you confirmed those 45 seconds the smoke shows up doesn't match with closed loop starting?
- Devin0789
