2008 dodge avenger 2.4 fans do not come on
  • chief eaglebear
  • chief eaglebear's Avatar Topic Author
5 years 2 months ago #51066 by chief eaglebear
2008 dodge avenger 2.4 fans do not come on was created by chief eaglebear
hi folks i have a vehicle with a overheat problem but it would only overheat when sitting idle after a full warm up or after restart after sitting for ten minutes or so i have no leaks i wanted to ask anyone if they can provide schematic for that fan circuit and description of operation if possible i just want to make sure module or what ever is getting proper signal from coolant input or whatever been a scanner danner student for awhile so i should have no excuse in my ability to diagnose it i just dont want to change fan assembly out unless i check it oput properly as i DO NOT WANT TO BE A PARTS CHANGER !!
5 years 2 months ago #51077 by jreardon
Replied by jreardon on topic 2008 dodge avenger 2.4 fans do not come on
The diagrams show a 4-wire fan module, but I think the module it's referring to is the fan assembly altogether, with 2 fans, 2 wires each, so 4 wires total. Basically a power and ground for each fan. When low speed is called for, one pin gets a power and the other pin gets a ground through the other fan. When high speed is requested each pin gets a power and a ground directly. So, you can just supply a power and ground to each fan and make sure they spin.
File Attachment:
File Name: fan_2021-09-02.pdf
File Size:1,528 KB
5 years 2 months ago #51084 by jreardon
RAD FAN RELAY CONTROL = ON
LOW/HIGH RAD FAN RELAY CONTROL = OFF
ONLY C2 FAN RUNS ON HIGH
LOW/HIGH RAD FAN RELAY CONTROL = ON
BOTH C1 and C2 FANS RUN ON LOW
BOTH C1 and C2 FANS RUN ON HIGH
16 minutes in
