2001 ranger 3.0 manual transmission
- Cheryl
- Thank you received: 215
I might not be understanding his situation. :silly:
- Cheryl
- Cheryl
- Cheryl
- Cheryl
Because of the Differential Gear assembly.why does only one wheel spin in the back while turning engine over with the breaker bar.
- Cheryl
- Hardtopdr2
- Thank you received: 150
- Cheryl
I'd say he's in the clear.So I’m going to assume the clutch splines and input shaft splines are lined up. So would you say he has a green light to keep going on this job?
- Cheryl
- guafa
- Thank you received: 80
Like some guys said. That's the way manual transmission works. If you shift into any gear and with clutch pedal released, you have total engage between crankshaft and wheels.
You can spin crankshaft freely, by lifting wheels or simply by pressing clutch pedal.
An old non orthodox practice when you have a starter issue and you need to turn engine on, is to engage fourth gear, with key on let the car gain impulse in a hill and suddenly release clutch pedal. That way you move crankshaft replacing starter function.
- guafa
Many manual transmission vehicles don't have safety electrical systems to avoid you fire starter into a gear shifted. (For instance two switches in series with starter control wire. One in clutch pedal and the other in transmission) .
So you have to be sure you are into neutral before you try to turn engine on without pressing clutch pedal. Other way you would move the whole vehicle by cranking.
- Cheryl
