Pin numbers at the ECU
- Nelixuk2003
- Thank you received: 2
5 years 1 month ago - 5 years 1 month ago #51458
by Nelixuk2003
Pin numbers at the ECU was created by Nelixuk2003
Hi All
Back again with another request for help
I have an Audi A1, 64 Plate that has a cam sensor open circuit code. the owner has changed the sensor based on the code and the issue is still present. Its a 3 wire sensor, Blue White and Brown, I'm hoping someone can tell me the pin numbers at the ECU so I can do some testing. gaining access to the Sensor requires quite a bit of digging and removal of parts which I am trying to avoid if its not required, access to the ECU is far easier.
Hope someone can help.
Last edit: 5 years 1 month ago by Nelixuk2003. Reason: Change model from S1 to A1
5 years 1 month ago #51460
Replied by Noah on topic Pin numbers at the ECU
Going to need a year and engine size/code to help you out.
- Nelixuk2003
5 years 1 month ago - 5 years 1 month ago #51461
by Nelixuk2003
Replied by Nelixuk2003 on topic Pin numbers at the ECU
Its a 64 plate (UK) so 2014/2015, 1.6 Diesel
- Nelixuk2003
5 years 1 month ago #51462
by Nelixuk2003
I have also amended the original post as its an A1 not an S1.
5 years 1 month ago - 5 years 1 month ago #51463
oh I see, thank you! Hopefully someone has service info for your domestic market, I do not
Last edit: 5 years 1 month ago by Noah.
