01 Nissan Xterra 3.3 engine
  • Wburke1
  • Wburke1's Avatar Topic Author
5 years 1 month ago #51577 by Wburke1
01 Nissan Xterra 3.3 engine was created by Wburke1
Hello. I have a 01 Nissan Xterra 3.3 engine. 201k miles. Installed a lower mile engine in the car. Because the other was on its last leg. But it ran. Now new issue. Crank no start. Have fuel, spark, rpm signal. Still not starting. Just spins over.
5 years 1 month ago #51578 by Cheryl
Replied by Cheryl on topic 01 Nissan Xterra 3.3 engine
You have fuel and spark?? Maybe the timing is off. Do you have a 5 volt reference? Maybe the injectors are stuck shut from sitting in the used engine. Try running it off alternative fuel source?
5 years 1 month ago #51580 by Tyler
Replied by Tyler on topic 01 Nissan Xterra 3.3 engine
I agree with Cheryl, try an alternate fuel source. Carefully. :silly: I say carefully because if the distributor is installed out of time, you may get a nice fireball in your face.
You could also use a timing light to verify spark is happening close to TDC.
