2014 Chevy Cruze ltz 1.4 turbo Crank no start with exhaust cam sensor plugged in
- Hardtopdr2
- Thank you received: 150
5 years 1 month ago #51838
by Hardtopdr2
Replied by Hardtopdr2 on topic 2014 Chevy Cruze ltz 1.4 turbo Crank no start with exhaust cam sensor plugged in
i even reduced it in size below 5 mb (4.52 mb) in png and still no go on upload lol
- Hardtopdr2
5 years 1 month ago #51840
by Hardtopdr2
ok managed to put it as a pdf finally it is zoom out to show the whole capture
- Cheryl
- Thank you received: 215
5 years 1 month ago #51841
by Cheryl
Replied by Cheryl on topic 2014 Chevy Cruze ltz 1.4 turbo Crank no start with exhaust cam sensor plugged in
Make sure you ain’t losing 5 volt ref and low reference. If it’s that intermittent I’d be half tempted to throw a new gm sensor in
- Cheryl
5 years 1 month ago #51842
by Cheryl
Is the intake and exhaust cam sensors the same part number? Maybe try swapping them
- Hardtopdr2
5 years 1 month ago #51843
by Hardtopdr2
I looked that up today and it looks like it is the same part number
- ScannerDanner
- Administrator
- Thank you received: 500
5 years 1 month ago #51846
by ScannerDanner
Don't be a parts changer!
Replied by ScannerDanner on topic 2014 Chevy Cruze ltz 1.4 turbo Crank no start with exhaust cam sensor plugged in
I have Luke on this!Hardtopdr2, the whole mimi error has been cropping up recently. I've found that using PNG instead of JPG gets around it. Sorry for the hassle.
The following user(s) said Thank You: Hardtopdr2
5 years 1 month ago #51848
Definitely swap the sensors, as long as it's halfway accessible. I got $5 that says you'll find a Dorman sensor in there.
Replied by Tyler on topic 2014 Chevy Cruze ltz 1.4 turbo Crank no start with exhaust cam sensor plugged in
Well I don't know any more, then. :silly: Just as soon as I've got it figured out...i even reduced it in size below 5 mb (4.52 mb) in png and still no go on upload lol
- Hardtopdr2
5 years 3 weeks ago #51967
by Hardtopdr2
Well I put a new one in and still threw the code and it was not a Dorman sensor in it and it still did not start with it plugged in. I also pulled the valve cover off to verify timing ( which miraculously it stopped perfectly lined up ) as well as center oiler plate to make sure it's tight and all was good in that respect. It did reset code p0365 as well after clearing them and trying to start it with new sensor plugged in. May try a crank cam relearn on it when I get back in town for grins. But not confident on it working given how everything else played out. Will let you know more when I get back to it.
- Cheryl
5 years 3 weeks ago #51969
by Cheryl
The only other thing I can think of is are the wiring terminals in the correct order? I had a Ford alternator where someone was messing around swapped pins in the connector. Bug it very well could be a pcm
- Jasondragon
3 years 11 months ago - 3 years 11 months ago #58834
by Jasondragon
Replied by Jasondragon on topic 2014 Chevy Cruze ltz 1.4 turbo Crank no start with exhaust cam sensor plugged in
When you have your cams on top dead center with the crank make sure the back of the cams are facing each other the cam lobes because if they're facing away on top dead center that means the cams are flipped because mine is doing the same thing it runs with the exhaust cam sensor unplug but when it's plugged in it does not run
Last edit: 3 years 11 months ago by Jasondragon.
- Jasondragon
3 years 11 months ago #58840
by Jasondragon
- Hardtopdr2
3 years 11 months ago #58848
by Hardtopdr2
Thanks for the info. The motor was swapped out from what I was told before I looked at it. Granted I don't remember which way the cams were facing as this was a year or two ago. But will keep in mind the next time I run into this. Most appreciated thank you
