Pajero io Mitsubishi[FIXED]
- Caritech
- Thank you received: 10
9 years 7 months ago - 9 years 6 months ago #7244
by Caritech
Pajero io Mitsubishi[FIXED] was created by Caritech
Hello all. A Mitsubishi Pajero io with a 4g93 sohc engine barely idles, revs when warm in P OR N only and is slow to respond, stalls if you add fuel source (carb cleaner) while idling, N light started to blink but not sure if it was doing that before I started working on it. The only code I'm getting is tps circuit (looks good on scan tool data stream) and I pulled the exhaust off still nothing. When cold you have to open the throttle to keep it running. O2 showing rich.
Coil, plugs, wires, MAFs, tps were tried by the previous shop. I'm going after contaminated fuel, valve issues or ckp somehow is out of place. Any thoughts?
Last edit: 9 years 6 months ago by Caritech.
- Ben
- Thank you received: 215
9 years 7 months ago #7251
by Ben
Replied by Ben on topic Re:Pajero io Mitsubishi
What is the code and what year
- Caritech
9 years 7 months ago #7252
by Caritech
Replied by Caritech on topic Pajero io Mitsubishi
14 tps circuit not sure of the year.
- Ben
9 years 7 months ago #7253
by Ben
Can you post the Vin number? I can get info that way
- GeekDIYMechanic
9 years 7 months ago #7256
by GeekDIYMechanic
Replied by GeekDIYMechanic on topic Pajero io Mitsubishi
Are the fuel trims ok? I would assume they are rich.
Have you verified MAF functionality, if applicable? Have you verified MAP functionality, if applicable?
I had one car act like crap because of a malfunctioning ECT. I suggest back probing it to see if is reading as expected.
BTW, I suggest when testing any of the above sensors to test at the sensor because you don't want to be mislead by substituted values via the scan tool.
When did the car run great last? Since that point, what events have happened, e.g. just driving, accident, tune up, part replacement, ....
- GeekDIYMechanic
9 years 7 months ago #7257
by GeekDIYMechanic
Just reading your post again, the blinking N concerns me.
Perhaps the transmission is having an issue that is causing it to put unexpected load on the engine.
I would look into that as well.
- Caritech
9 years 7 months ago - 9 years 7 months ago #7541
by Caritech
Did some thinking. The reason I'm seeing a tps code is the the PCM is seeing the maf showing idle speed air flow while the tps is going up to WOT when we are trying to rev. The PCM is not increasing injector pluse width when throttle is being opened.
The engine seems not to be breathing.
Last edit: 9 years 7 months ago by Caritech.
- Caritech
9 years 6 months ago #8638
by Caritech
Problem was the key broke on the crank causing timing to go to crap.
