P069e
  • Bsbrummett
  • Bsbrummett's Avatar Topic Author
5 years 3 weeks ago #52014 by Bsbrummett
P069e was created by Bsbrummett
I have a 2012 cadillac srx 3.6 that has been throwing code p069e changed fuel pumps one in the tank and on the engine.  Put new fuel injectors new ecm still throwing the code and now throwing p2635 low flow performance can't figure what it is.  Couldn't find any breaks or corrosion on wires.  Help
5 years 3 weeks ago #52029 by Cheryl
Replied by Cheryl on topic P069e
Does it start and run? Or crank no start?
  • Bsbrummett
5 years 3 weeks ago #52030 by Bsbrummett
Replied by Bsbrummett on topic P069e
It does start and runs until it gets warm then it has a hard time starting until it cools back down while driving it just quits like it runs out of fuel but has 3/4 of a tank
5 years 3 weeks ago #52031 by Cheryl
What does your fuel pressure sensor read? Should have a high and low side sensor
5 years 3 weeks ago #52032 by Desmond6004
Replied by Desmond6004 on topic P069e
Check that there aren't any melted pins at the fuel tank plug.
  • Bsbrummett
5 years 3 weeks ago - 5 years 3 weeks ago #52033 by Bsbrummett
15 psi was the max
Last edit: 5 years 3 weeks ago by Bsbrummett.
5 years 3 weeks ago #52048 by Tyler
Replied by Tyler on topic P069e
P069E is just a road sign code to the Fuel Pump Control Module. P2635 is the code to follow for now.
Can your scan tool access the FPCM? Can you observe the actual fuel pressure and desired fuel pressure? What are the fuel pump trim values?
