Parking brake light on dash comes on while driving 2006 dodge ram 2500 5.7
- Mechanic 350
- Thank you received: 15
5 years 1 week ago #52287
by Mechanic 350
Parking brake light on dash comes on while driving 2006 dodge ram 2500 5.7 was created by Mechanic 350
I need some direction. My parking brake light comes on while driving. When I connected my maxisys to my truck it said nothing of any code related to e-brakes. Master cylinder looks good no leaks and has plenty of fluid. Need some direction. Diyer here. Thanks
5 years 1 week ago #52296
Replied by Tyler on topic Parking brake light on dash comes on while driving 2006 dodge ram 2500 5.7
No codes in the ABS for low fluid level? I know you checked the level, but that doesn't mean there isn't a circuit fault.
I'd also look at the parking brake switch circuit, and the parking brake pedal switch itself. You could start by disconnecting the parking brake switch and drive it again. If the light now stays off, investigate the pedal further.
- Mechanic 350
5 years 1 week ago #52297
by Mechanic 350
Replied by Mechanic 350 on topic Parking brake light on dash comes on while driving 2006 dodge ram 2500 5.7
No codes in the abs system.
I will check the brake pedal switch next. I don’t have a wiring diagram yet. But I will check for power, ground and signal wire. I’ll figure out what type of switch input I have after unplugging the connector. Thanks Tyler.
- Mechanic 350
5 years 1 week ago - 5 years 1 week ago #52306
by Mechanic 350
this is what my autel reported it.
circuit is a pull down switch input.
test light to ground and it pulled it down to ground no problem. circuit is good.
Last edit: 5 years 1 week ago by Mechanic 350. Reason: Adding photo
- Mechanic 350
5 years 1 week ago #52307
by Mechanic 350
Screen capture
