1989 Ford F-150 5.8L
- Mike T
- Thank you received: 2
5 years 1 week ago - 5 years 1 week ago #52340
by Mike T
1989 Ford F-150 5.8L was created by Mike T
Okay guys I need someone that has play mechanic on the older ones to tell me what the little capacitor thing is on the side of the coil. Looks like the capacitor in the old distributors but it’s just bolted to the side of the coil with a big plug on it.
Last edit: 5 years 1 week ago by Mike T.
- paulctownsend
5 years 1 week ago #52342
by paulctownsend
Paul Townsend
Replied by paulctownsend on topic 1989 Ford F-150 5.8L
iTS FOR RADIO STATIC ONLY. WILL RUN JUST FINE WITH OUT IT. ON RARE ACATIONS THAT DEVICE WOULD SHORT OUT CAUSING NO POWER AT THE + SIDE OF THE COIL.
Paul Townsend
The following user(s) said Thank You: Mike T
- Mike T
5 years 1 week ago #52343
by Mike T
Replied by Mike T on topic 1989 Ford F-150 5.8L
Do you know the name of it?
- paulctownsend
5 years 1 week ago - 5 years 1 week ago #52344
by paulctownsend
Paul Townsend
RADIO NOISE SUPPRESSOR . JUST LIKE A POINTS IGNITION SYSTEM CONDENSER.
Paul Townsend
Last edit: 5 years 1 week ago by paulctownsend.
5 years 2 days ago - 5 years 2 days ago #52450
Replied by Andy.MacFadyen on topic 1989 Ford F-150 5.8L
It allows the high voltage AC voltage spikes that occur in the primary after the end the spark when the coil is "ringing" a path to ground.
It is a simple capacitor - capacitors allow an AC voltage to pass but block DC by damping the ringing it suppresses radio interference
Last edit: 5 years 2 days ago by Andy.MacFadyen.
