U0109 p069e
  • autojoe
5 years 1 week ago #52369 by autojoe
U0109 p069e was created by autojoe
Did anyone ever get above codes without any driveability problems? Dealer replaced fpcm only problem is light on. I know usually a no start or poor running. Any ideas.
5 years 1 week ago #52373 by Chad
Replied by Chad on topic U0109 p069e
I would start with fuel pressure scan data.  Does actual match desired? Does scan data match mechanical gauge reading?
  • autojoe
5 years 1 week ago #52375 by autojoe
Replied by autojoe on topic U0109 p069e
Thanks for the reply but the u0109 is set because of pcm does not have comm between fpcm and pcm. So not a fuel pressure issue only thing odd is no driveability problems or starting problems. Clear light comes back on. Maybe pcm is bad. Have to verify can inputs to pcm 4 wires then if good probably bad pcm.
5 years 1 week ago - 5 years 1 week ago #52376 by Chad
Hmm. I assumed that communication was present, because I believe this module needs programmed. This is a GM?  Was the dealer able to program it? I assumed the dealer was able to program it.  Can YOU access the FPCM with a scan tool? I wouldn't be condemning the PCM, yet. I'll check out the Network Com diagrams.
Last edit: 5 years 1 week ago by Chad.
5 years 1 week ago #52377 by Chad
What YMME?
5 years 1 week ago #52378 by Tyler
Replied by Tyler on topic U0109 p069e
What's the YMME? The dealer has already replaced the FPCM?
  • autojoe
5 years 1 week ago #52381 by autojoe
Will have to test power ground and outputs from fpcm to pcm at fpcm and pcm. Just trying to help someone and never encountered a u0109 with a good running vehicle. Starts and runs fine. I will keep you posted. Thank you.
