Long cranking cold start
- DragoT
5 years 2 days ago #52413
by DragoT
Long cranking cold start was created by DragoT
Hi guys,
The car is GM Opel Frontera (in North America I think is Isuzu Rodeo) from 2000 with 2.2 petrol engine(X22SE). Customer complain is hard start and long cranking
when the engine is cold. He came from other shops where changed plugs, HV wires, fuel filter, cam sensor, known good Injectors (with fuel rail and pressure regulator) and known good fuel pump.
No DTC set. In the morning I tried to start the engine. While cranking engine almost started. ECT, IAT, TPS, cam speed and RPM data was good. After 4-5 attempts finally runs. I drive the car several miles. Runs fine, no stall, good acceleration. For
the rest of the day starts immediately every time.
The next morning I used start spray and engine runs immediately. So I decided it was some sort of fuel delivery issue. Fuel pressure was 50 psi with key on and drops to 30 after several minutes. Stable 60 while cranking (measured with gauge) Service manual says it should be around 50. Drop the tank and check pump o-ring, hoses and etc..everything seems fine. Fuel lines from the tank to the rail are good. Injectors resistance in spec, feed and control wires ok ( test light method). No stuck or leaking injectors too - I take it to another shop for test. Cylinders compression is in spec. Also checked load fuel pump circuit - good ground and power.
Any ideas and suggestions are welcome. Unfortunately I don’t have scope, only scanner, multimeter and test light.
P.S.
Please excuse my English.
P.S.
- eric.campbell1
5 years 1 day ago #52435
by eric.campbell1
Replied by eric.campbell1 on topic Long cranking cold start
Had a Rodeo recently had similar symptoms, turned out to be a simple vacuum leak and a computer reset. Maybe smoke test and make sure routing is correct, my find was an improperly routed fuel pressure regulator vacuum at the back of the fuel rail. And a few days driving (didn't even fix it right away lol) it was back to normal. Support for these cars are limited I had to use OBDII mode to diagnose lol.
Good luck
Good luck
- Anthony78
2 years 3 months ago #66254
by Anthony78
Replied by Anthony78 on topic Long cranking cold start
Hello!
Would like to ask, did you fix the problem with the X22SE? No i have a same problem on a same engine, same, car. What was the solution, or what was the cause of the problem. I checked and tested a
Ot, but i have no idea anymore. 100% the same problem.
I saw it is an old post in the formu, but i hope you will read it.
Thank you, Anthony
Thank you, Anthony
