honda no start
  • mikieb
  • mikieb's Avatar Topic Author
  • love to work on car
5 years 2 days ago #52460 by mikieb
honda no start was created by mikieb
2006 Honda civic si 2.0 customer installed owen tranny clutch, know a no start, first started with no communication with computer check power grounds found fuse blown got some communication going on, set code for crank sensor scoped it and found no signal has spark and injector pulse pull plugs they was wet fouled out compression 120 /150 lbs
re[place plugs keeps fouling plugsĀ
mikieb
5 years 1 day ago #52469 by Noah
Replied by Noah on topic honda no start
What exactly are the codes that are setting?
If you have spark and injection pulse the crank sensor must be working, can you see RPM on the scan tool while cranking?
Minimum compression for that engine is 135psi, with a maximum variation of 28psi between cylinders.
If you recorded 120-150 you're just outside of the "normal" range on both counts. If the plugs are fuel fouling cylinder wash could contribute to this.
Over fueling during cranking can be from a bad input like a coolant temp sensor. On a cold start it should read very close to what is being reported by the ambient air temp sensor and the intake air temp sensor.
Does the engine sound like it cranks normal? I have seen someone accidently spin that engine backwards during a clutch job which can cause the timing to jump.
That would give you a crank-no start with fuel, spark and fouled plugs.
  • mikieb
5 years 1 day ago #52476 by mikieb
Replied by mikieb on topic honda no start
Codes was po335 no signal for crk ,yes there is rpm and injector pulse, rpm on this vehicle makes it from cam signal when cri is miss I thinking because there was rpm so I put a scope on it and ther was nothing while I have the scope out (my 2 channel snap on ) with a new good crk sensor I looked at crk/ both cam and cop coil on number one and from the best I can tell it's out off time ,and yes I think they turn the engine backwards too so thank you for the in put
mikieb
