No spark no opening of nussle
  • Victor111
  • Victor111's Avatar Topic Author
4 years 11 months ago #52618 by Victor111
No spark no opening of nussle was created by Victor111
Comments / Questions: I had this Toyota corrola 1994 model with no spark no openings of nussle.... So i did some check on the connections and all was okay amd due to my check i found out that the ecu is not receiving signals from the ignition and i had to pull out the wires that's sending signals to the ecu with my key turn on(ignition) and uses that wire sending signals to the ecu to touch the grounded area(negative) of the engine block den o had a spark and openings of nussle at a time, due that i decided to go get some complete distributor and no spark unless i did it that way again, could it be my ecu's fault or the wiring or probably igniter??
4 years 11 months ago #52628 by juergen.scholl
Replied by juergen.scholl on topic No spark no opening of nussle
See the attached document for trouble shooting. According to your description I would not be surprised if you found a wiring issue....
File Attachment:
File Name: Corolla94i...heck.pdf
File Size:1,039 KB
The following user(s) said Thank You: Noah, Victor111
