87 Blazer TBI no injector pulse
  • lzjr88
  • lzjr88's Avatar Topic Author
4 years 11 months ago #52694 by lzjr88
87 Blazer TBI no injector pulse was created by lzjr88
1987 Chevy K5 Blazer, 5.7L engine 4-speed auto. Complaint – TBI Injectors won’t pulse fuel when cranking the engine, then after spraying either into the throttle body it will start and the TBI injectors spray fuel but the engine will surge from about 800 RPM to about 1800 RPM in a cyclic rhythm. I started by repairing the obvious issue of the injector wiring harness that was burned with exposed wires / issue still persisted. I then noticed one of the two injectors was not spraying fuel, it was just dribbling fuel as the other sprayed. I rebuilt the TBI unit and got it to operate properly (both injectors spraying fuel) / issue still persisted. I attached my ancient “brick” Snap-On scanner to the OBD I connector and was able to watch the available live information but all of the sensors were within specification and there were no trouble codes. I then taped into the fuel line to check the pressure. On initial prime the pump only showed about 3-4 PSI and while running it was only about 5-6 PSI. I replaced the in tank fuel pump, checked the initialization prime (11 PSI) and then the operating pressure (11-12 PSI) / issue still persisted. I then checked continuity of the wires going from the distributor to the ECM, no shorts or opens with perfect continuity. I then began to throw parts at it. I installed a new ECM / issue still persisted. I installed as new distributor / issue still persisted. I checked the reference wire from the distributor to the ECM by connecting a test light to battery positive and turned the ignition on (KOEO) and then touched the reference wire and the injectors would pulse. I think I’ve pretty much proven that each individual part of the system works on it’s own but I cant figure out why all of the parts wont work together.
4 years 11 months ago #52701 by juergen.scholl
Replied by juergen.scholl on topic 87 Blazer TBI no injector pulse
Though you state all of the sensor's data shows normal: what is.the tps at? It may be reporting high voltage=full throttle and hence fuel cut during crank occurs. I've seen this more than once.
  • lzjr88
4 years 11 months ago #52706 by lzjr88
Replied by lzjr88 on topic 87 Blazer TBI no injector pulse
I can't recall at this time what the TPS was at but I'll make that the first thing I check on Monday morning. Thanks!
4 years 11 months ago #52707 by ontheriver
Replied by ontheriver on topic 87 Blazer TBI no injector pulse
Were the sparkplugs filthy? I would think the egr and passage is filthy, possibly not sealing well, the iac is trying it's best, but there is unmetered air entering
4 years 11 months ago #52711 by ontheriver
How about a i.a.c. reset, go to TBI-Initial-calibration.pdf-GMCMI
  • lzjr88
4 years 11 months ago #52712 by lzjr88
I haven't checked the spark plugs but I will take them out and see what they look like. I also forgot to mention that I did attempt to do the IAC reset before I rebuilt the TBI unit. However I haven't attempted it since the rebuild. I'll give that a go tomorrow.
More follow on information I just got from the owner: The blazer ran fine and would start without any issues. He had a head gasket issue and "blew the engine up" so he replaced the motor with a stock crate motor from Jegs. He said that the TBI no start and pulsing issue started immediately after he finished the installation. He also told me that he replaced the IAC, IAC connector, Spark Module and Throttle Position Sensor but the issue dint resolve itself so the blazer found it's way to me.
I really appreciate the feedback and advice. I'll check on all of the suggestions given to me tomorrow and see what comes of it.
4 years 11 months ago #52715 by ontheriver
With that info, Add a exhaust back pressure test, the cat could be compromised
4 years 11 months ago #52720 by Cheryl
Replied by Cheryl on topic 87 Blazer TBI no injector pulse
I’d voltage drop the grounds at the pcm since he had the engine out. Do I while cranking. Probably won’t find an issue but never know
  • lzjr88
4 years 11 months ago #52820 by lzjr88
I apologize for the delay; my wife took leave for Thanksgiving so I took time off to be with her and our kids. Just got done checking all of the suggestions, here are the results:
IAC Reset - Complete
Throttle Position Sensor voltage - When the engine would surge it was at .94 to .98 volts at 800 RPM and 1.12 to 1.14 volts at 1250 RPM. However today is the first time it went from surging to a constant high idle intermittently. It would go up to 1500 RPM all on its own and the TPS voltage would be at 1.44 volts (and I never touched the throttle). I also noticed the IAC would go from 90 to 104 when it was surging and stay at 144 when it was high idling. I then noticed the O2 sensor would read Lean, the mV reading would be at .004 and it showed no cross counts. When at high idle it would read rich then lean, the mV reading was around.500 and the cross count would start to register. The whole time it said it was in a closed loop. Every time it would high idle, I'd let it stay there for about 2-3 minuets then I'd hit the throttle to WOT then it would back down and begin to surge again. It would surge for about 2 minutes and go back to the high idle.
Exhaust back pressure - None, it's got straight pipes from the manifolds out to the back.
Voltage Drop for the Grounds - Unfortunately I couldn't find an issue here.
Spark Plugs - They were clean, no carbon build up.
Would the PROM be causing any of this or should I just build a new harness between the distributor and the ECM? Thanks again for all of your assistance.
4 years 11 months ago #52826 by ontheriver
With straight pipes, I think your going to need a heated 02 sensor
4 years 11 months ago - 4 years 11 months ago #52833 by guafa
Replied by guafa on topic 87 Blazer TBI no injector pulse
Hey guys.
At this point i'm not sure surging or high idle is due to IAC issue or a vacuum leak. I suggest two tests.
1. While engine idling and not touching throttle, unplug IAC. Like if it were a carburetor, rpm should stay constant (surging should stop).
2. Still IAC unplugged,
very slowly block off IAC passage with one of your fingers. That should drop rpm to something about 700 rpm. Because you are reading TPS voltage above 0.8v, i'm guessing your new rpm should be high (if i remember well, factory setting is 0.45v).
On the other hand, there are 3 PID's that can help you to know whether or not you have an IAC calibration issue (target rpm, actual rpm and iac steps).
If target rpm is lower than actual rpm, iac steps tend to go down and viceversa.
Let's say engine is idling at 1500 rpm. Then ecu tries to reduce the amount of air by closing IAC passage. Then suppose iac steps goes to 0 and engine is still idling high. That means you have throttle blades too open or you have a vacuum leak.
Last edit: 4 years 11 months ago by guafa.
4 years 11 months ago #52835 by guafa
What are map readings at surging/high idle?
What is your local baro pressure?
  • lzjr88
4 years 11 months ago #52868 by lzjr88
At high idle the MAP is at 22 and .94 Volts. When the engine is surging the MAP is at 21 and .64V. My current local barometric pressure is 30.16 in (according to weather.com).
4 years 11 months ago - 4 years 11 months ago #52870 by guafa
Ok guys.
30.16 in/hg means you are very near to sea level.
The maximum vacuum you are reporting (30.16 - 21 = 9.16 in/hg). That is too low.
Am i right? I usually work with Kpa, so please re-check.
  • lzjr88
4 years 11 months ago #52875 by lzjr88
You are correct on my location being close to sea level, my shop is about 7.5 miles Northwest of the Crystal Coast on the Atlantic Ocean (Hubert, NC about halfway between Wilmington, NC and Morehead City, NC). My elevation is 30 feet above sea level. Based on my conversion chart 30.16 inHG (inches of mercury) is equal to 102.13 kilopascals (kPa). Based on your calculation I'm not certain of what numbers/units you're looking for?
4 years 11 months ago - 4 years 11 months ago #52876 by juergen.scholl
Guafa is referring to the manifold pressure at (high) idle your eported. A sound engine at your altitude should produce an vacuum of around 18 to 21 ``Hg at idle. This would result in an ABSOLUTE pressure in the manifold of 10 to 12 ``HG. The number you`re giving is 22``Hg. This equals to to only 9``Hg which is a VERY low value.
Depending on the scantool you use it can be easy to mistake engine vacuum for absolute manifold pressure. IF the reported pids were swapped this would be represetative of a good breathing engine at idle condition....
Make sure you really are reading manifold vacuum as such and manifold pressure as manifold pressure. If in doubt about scan data just put a vacuum gauge on it.
Last edit: 4 years 11 months ago by juergen.scholl.
The following user(s) said Thank You: guafa
Time to create page: 0.411 seconds
