Re:2008 Ram 5.7 Stalling
  • 69Sidepipes
  • 69Sidepipes's Avatar Topic Author
4 years 11 months ago #52825 by 69Sidepipes
2008 Ram 5.7 Stalling was created by 69Sidepipes
2008 Ram 5.7 2500 Stalling when stopping No trouble codes starts back immediately. I cleaned the throttle body still have the same issue.
4 years 11 months ago #52827 by Noah
Replied by Noah on topic 2008 Ram 5.7 Stalling
I would try a battery disconnect along with the throttle cleaning you already did before going too much deeper.
4 years 11 months ago #52845 by Tyler
Replied by Tyler on topic 2008 Ram 5.7 Stalling
Before going too deep, check the transmission fluid level. Low level can cause the torque converter to stick applied while coming to a stop. They usually won't set codes with this issue.
Most Ram transmissions are checked at idle in Neutral, not Park.
  • 69Sidepipes
4 years 10 months ago #53023 by 69Sidepipes
Replied by 69Sidepipes on topic 2008 Ram 5.7 Stalling
I've done the battery disconnect and still have issue. I have set P0335 code on two different occasions and also a misfire code once. Can I bench test a crankshaft sensor with 12v battery and multi meter? I thought i read that sensor is activeted with 5v.
4 years 10 months ago #53024 by Ben
Replied by Ben on topic Re:2008 Ram 5.7 Stalling
Did you check transmission fluid level as Tyler suggested?
  • 69Sidepipes
4 years 10 months ago #53034 by 69Sidepipes
Replied by 69Sidepipes on topic Re:2008 Ram 5.7 Stalling
I added a quart of trans fluid. Although the truck will also drop to zero rpm and instantly return to normal rpm while crusising on the interstate.
4 years 10 months ago #53043 by Cheryl
Replied by Cheryl on topic Re:2008 Ram 5.7 Stalling
If you do not have a oscilloscope your best bet is to replace both cam and crank sensors with oem sensors not aftermarket
