Fuel pressure gauge rapidly fluctuate
- Cheryl
- Thank you received: 215
4 years 11 months ago #52849
by Cheryl
Fuel pressure gauge rapidly fluctuate was created by Cheryl
Checking low side fuel pressure on a 2009 enclave 3.6. My Mac fuel pressure gauge fluctuates very rapidly at idle. But if we hold the throttle steady it gets solid at 56 psi. Is it because of the direct injection?
- Cheryl
4 years 11 months ago #52850
by Cheryl
Replied by Cheryl on topic Fuel pressure gauge rapidly fluctuate
The desired and actual fuel rail pressure match under load. If the low side fuel pump was going out the high side would be low I’d assume
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 11 months ago #52853
by juergen.scholl
Replied by juergen.scholl on topic Fuel pressure gauge rapidly fluctuate
With GDI the low pressure side is module/pwm controlled, right? If so: are there data pids for desired and actual pressure? Did you test the gauge on other vehicles recently as an excessive fluttering of the needle is not something "typical" to GDI systems in my book.
- Cheryl
4 years 11 months ago #52854
by Cheryl
The only Pisa I have are for the high side that I can see. The desired and actual match. Do t see one for low side though. Yes it’s pwm. Probably just current ramp the pump and go from there.
- Cheryl
4 years 11 months ago #52855
by Cheryl
Pids
4 years 11 months ago #52860
Replied by Tyler on topic Fuel pressure gauge rapidly fluctuate
You may need to find the Fuel Pump Control Module to see the low side desired and actual.
