2016 ram 2500 6.4 hemi P2305,P0302
- Jostr
4 years 11 months ago #52883
by Jostr
2016 ram 2500 6.4 hemi P2305,P0302 was created by Jostr
I'm a bit stumped y'all, I was looking at a 2016 ram 2500 6.4 hemi the issue I have is I've got 2 codes p0302 and p2305. I played swaptronics and swapped #2 coil and plug to #4 misfire stayed on #2. For some reason the PCM continued to limit injector pulse after a few seconds of running on #2. I'm confused because the original #2 coil work fine in #4 cylinder. Is this a PCM strategy I'm not aware of.
Attachment not found
- Ben
- Thank you received: 215
4 years 11 months ago #52884
by Ben
Replied by Ben on topic Re:2016 ram 2500 6.4 hemi P2305,P0302
It sounds like you've confirmed it is not the plug or coil causing the misfire. If this is anything like the 5.7 hemi I would suggest a relative compression test (not conventional) or even better a running compression test you will likely find a wiped out camshaft causing valves not to open...
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 11 months ago #52885
by juergen.scholl
To avoid damage to the catalytic converter many engine management systems, especially on recent platforms, will cut injector pulse to an offending cylinder in case of a detected specific misfire. The computer may not know the exact reason of the misfire and with this preventive move ensures that no possibly unburned fuel will light off in the converter destroying it.
Replied by juergen.scholl on topic 2016 ram 2500 6.4 hemi P2305,P0302
- Jostr
4 years 11 months ago #52886
by Jostr
Replied by Jostr on topic 2016 ram 2500 6.4 hemi P2305,P0302
Yeah I know about the removing pulse for misfires but I couldn't figure out why it didn't come back after changing the coil out.
- juergen.scholl
4 years 11 months ago - 4 years 11 months ago #52887
by juergen.scholl
From your first post I understood that after swapping coils the injector pulse actually did return for a couple of seconds before it was shut off again. If this is true then the misfire condition keeps to be present. As Ben pointed out the misfire is not related to the components you just swapped.
Last edit: 4 years 11 months ago by juergen.scholl.
- Jostr
4 years 11 months ago #52888
by Jostr
Gotcha had to reread what yall had said. Thanks I'll dig deeper
