2010 MazdaSpeed3 Boost Issues
  • ltmrboyd
  • ltmrboyd's Avatar Topic Author
4 years 10 months ago #53082 by ltmrboyd
2010 MazdaSpeed3 Boost Issues was created by ltmrboyd
2010 Mazda Mazdaspeed3
This is the 2.3L turbo version of the Mazda3. The car is heavily modded with a new bigger turbo and built engine internals. Car used to hit boost targets of 21-23psi but currently having a boost issue where it hardly reads any boost. Boost control solenoid/throttle body and anything pretty much obvious has been swapped out at one point. Cat converter is not clogged.
Boost will hit 3..4…5…and then jumps back down to -1 and so on. Car will hit 10/14psi on WOT.
We have done a pressurized boost leak test/Smoke test and confirmed turbo doesn’t have any issues considering it only has maybe 1000 miles on it. EBCS is a 3 port MacValve. Fuel trims/AFRs are normal. Not a tuning issue mainly because it didn’t have this issue previously under the same tune.
4 years 10 months ago #53084 by juergen.scholl
Replied by juergen.scholl on topic 2010 MazdaSpeed3 Boost Issues
I only see two possibilities: There is no high airflow created at all by the turbine or there is no restriction to build up boost pressure. The later typically is caused by any kind of leak within the intake system. Your tests did not reveal a leak. If this is true you then may have a problem with the turbocharger itself.
Time to create page: 0.250 seconds
