5.3 No control power to Fuel Pump Relay
- 19taylor57
4 years 10 months ago - 4 years 10 months ago #53091
by 19taylor57
5.3 No control power to Fuel Pump Relay was created by 19taylor57
2006 GMC Serria 1500 5.3 4x4 single fuel tank. I had the motor out for total rebuild that took about 3 months due to work and part delays. I decided I would PUMP the old E10 fuel out and start off with fresh fuel before even trying to start it. Soooo I disconnected the fuel line from the rail, connected a hose down to plastic tank for disposal. Turned the ignition key to on and got nothing. Checked fuses, fuel pump, ECM & PCM swapped relays, all is good. I jumped the relay out and got the old fuel removed. So, I did not have this before I pulled the engine, what changed. As a part of the rebuild I installed ALL new sensors. I have triple checked all connections and grounds. I spent most of yesterday on the web, but as you know it was all over the place. I signed up with Alldata to see wiring. Looks very straight forward, PCM #9 Grn w/wht stripe is the control signal to the Fuel Pump. I tested it and there is no power. Am I looking at this right????? What tells the PCM to send the control signal. If it's just the key being on, then if I can't get his figured out, could I not just turn this into a Anti Theft by adding a hidden control power switch to the relay???? WELL I'm sure you all have figured out that I know just enough to be really dangerous. TYIA CHEERS
Last edit: 4 years 10 months ago by 19taylor57.
- Matt T
- Thank you received: 276
4 years 10 months ago #53093
by Matt T
Replied by Matt T on topic 5.3 No control power to Fuel Pump Relay
A fuel pump might run for a couple seconds when the key is first turned to run. To run it any longer than that, or at all, the PCM has to see engine movement. Easiest way to do what you want is to pull the relay and jumper the pumps power circuit.
- 19taylor57
4 years 10 months ago #53094
by 19taylor57
Replied by 19taylor57 on topic 5.3 No control power to Fuel Pump Relay
My post states that I pulled the relay and jumped it to remove old fuel. What I am trying to figure out is why I do not have control power to the fuel pump relay when I turn the key on.
- ontheriver
- Thank you received: 16
4 years 10 months ago #53095
by ontheriver
Replied by ontheriver on topic 5.3 No control power to Fuel Pump Relay
Do you have a scanner?, You could check for temperature from iat and cts to see if pcm is powered and grounded, with key in run
- autojoe
- Thank you received: 7
4 years 10 months ago #53105
by autojoe
Replied by autojoe on topic 5.3 No control power to Fuel Pump Relay
There should be a ignition input from ignition switch to the pcm 12 volt feed. Do you even hear the fuel pump run for 2 seconds koeo? Probably not. Do you have pcm pinout diagram?
- autojoe
4 years 10 months ago #53106
by autojoe
If you had a problem with the fuel pump relay control side ground circuit you would not have fuel pump operation. Take a test light connected to battery positive and remove relay touch each terminal should light on 2 one is control side ground other fuel pump load side finding ground through fuel pump brushes low resistance
- autojoe
4 years 10 months ago #53107
by autojoe
Sorry on my second post read no power on control wire from pcm. Check ignition switch inputs to pcm.
- autojoe
4 years 10 months ago #53108
by autojoe
If pcm wasn't getting ignition input signal before was called crank signal then pcm would not ground starter relay. Will your truck crank? Pcm fuel pump 2 second prime koeo? Maybe open fp control wire check 12 volts on control wire at pcm pin 9 dark green /white wire.
- Hardtopdr2
- Thank you received: 150
4 years 10 months ago - 4 years 10 months ago #53152
by Hardtopdr2
Replied by Hardtopdr2 on topic 5.3 No control power to Fuel Pump Relay
Some things to consider is mice love to get under the fuse block in the engine compartment. (I have the same truck) so pull fuse block up and check the wires underneath going to the relay spots.
Last edit: 4 years 10 months ago by Hardtopdr2.
4 years 10 months ago #53155
Replied by Noah on topic 5.3 No control power to Fuel Pump Relay
I would start will live scan data and see if the PCM commanded state of the fuel pump relay displays "on".
Time to create page: 0.366 seconds
