2012 Mini Cooper Base Error Code 2789 Fuel Mixture Adaptation but running well
- SamM
- Thank you received: 3
- Dtnel
- Thank you received: 67
Taking a rough shot in the dark I was able to come up with this regarding the code & description
"P2789 - Clutch "A" Adaptive Learning at Limit
Description :
The clutch actuation circuit is closely monitored for temperature and pressure variations. A fault code is stored if such a condition occurs. Temperature and pressure anomalies can cause damage to system components so a vehicle may enter limited operating strategy (limp mode) if this code is stored. The clutch actuator is also monitored for excessive wear, so a calibration must be carried out anytime there is a repair to the vehicle. This is carried out using a diagnostic tool.
Possible Causes could be :
Component
or
Mechanical Defect"
Given that description I did notice a few descriptors missing for vehicle information that you posted that could be a little more helpful in some instances. What trim level is this vehicle, is it a coupe, sedan, convertible. Automatic or manual transmission? Also being that this vehicle sat for two years have you went through and checked out all of the fluid levels with the vehicle cold and also once the vehicle has warmed up? Keep in mind with fluid levels that even though they may have been good before the vehicle sat overtime fluids tend to attract moisture.
Note, This post was done using voice to text speech recognition. I apologize ahead of time for any grammar errors or omissions.
If you have any other questions please feel free to ask as there are many others here who will most likely chime in as well. Before I forget about it have a happy holidays when you get around to it as well and don't eat too many cookies that are meant for Santa. Ha Ha.....
- SamM
For a lean idle fault, I'd first suggest checking crankcase pressure with a manometer in the dipstick port. They're too cheap to not have one.
www.amazon.com/Manometer-RISEPRO-Digital...ential/dp/B01680C4C2
www.amazon.com/Mityvac-MVA6912-Diagnosti...er-Kit/dp/B007TMSN5G
Specification is 36 mbar +/- 4 mbar. That translates to around 14 inH20, or 1 inHg.
- SamM
Thanks. What will this pressure tell me?
If the vacuum is significantly higher than spec, it's a smoking gun for a failed valve cover. I've heard of people taking them apart and replacing the diaphragm/membrane inside that makes the magic happen? Never done it myself, but it's an option.
If the vacuum is in spec or low, then that means the diaphragm/membrane is likely fine, and you're looking for vacuum leaks/unmetered air. That includes things like oil fill caps, dipstick seals and pinched valve cover gaskets. Those aren't the only ways to get unmetered air, just the most common ones I've seen.
- SamM
Thanks. I just replaced the valve cover gasket and the pvc membrane on the cover so hopefully I did it right. Appreciate the advice.
No worries. I'm sorry if I sound like I'm doubting your repair or workmanship. :blush: Genuinely not.
- SamM
- SamM
- SamM
The airflow rate *could* be indicative of an issue? The general rule-of-thumb is that the MAF should read the same in grams/second as the displacement of the engine in liters. So, if you had a 3.0L engine, your MAF should indicate 3.0 g/s at hot idle with no loads on.
I put your 3.8 kg/h reading into a converter and got around 1 g/s. Technically, that's low, and suggests unmetered air. That'd agree with the 2789 code you retrieved earlier. BUT, things also get more complicated with this engine due to it's low displacement and variable valve lift system.
If you're intent on getting another scanner, I'd suggest going with Autel. I own one of both, but still find myself reaching for the Autel more.
- SamM
- juergen.scholl
- Active partschanger
- Thank you received: 462
Quick tip: divide the kg/h by 3.6 to get your g/sec without calculator ( or, - roughly - ÷7*2).
You will see your scan data refers to an adaptive correction and another one called multiplicative, in your case the latter one being lower. German cars use these terms to distinguish between idling/low rpm and off idling condition. Adaptive correction describes idle/low load( below 1200rpm/ at least on VAG products, BMW/MINI might be≤1000rpm,not sure) where as multiplicative reflects higher rpm/loads. The scan data shows more ft correction at idle, supporting the idea of possibly unmetered air as Tyler already mentioned.
In combination with the input from other sensors like ckp, tps and like ones the control unit looks for to be expected values for the maf reading as well. The plausibility code will be flagged when the comparative data doesn't jive. In your case it could be a vacuum leak but there are more possibilities like an out of calibration mat sensor. The smoke machine will take a good step ahead n your diagnostic journey.
Just in case you haven't already explained somewhere else: I still would like to know what finally made the engine start after the initial problems you described in the other thread.
- SamM
- SamM
- juergen.scholl
- SamM
- Dtnel
Thanks. I wish I had more diagnostic knowledge but this forum is very helpful. I ended up getting my car running by replacing the fuel filter assembly which contains the fuel pressure regulator and hoses to fuel pump. Don’t know if spraying starter fluid in my earlier tests could have negatively affected the throttle body. So many sensors but will see if the smoke test yields anything and then go from there. Appreciate the help.
Don't sweat the knowledge part as it comes with time and we're all still learning all the time. If I tell you I don't learn something every day then I'd probably be lying. One of the others posting in this thread has the signature that sums it up as well. Can't recall it off the top of my head but it can't be missed
- SamM
